Testverslag Axi 5325/24
Kreeg dit docje toegestuurd door iemand. Voor wat het waard is?!
PRELIMINARY REPORT ON THE TEST FLIGHT OF AXI 5325/24
F3A ROI-IMPORT TEAM<O:p></O:p>
<O:p</O:p
Objectives:<O:p</O:p
<O:p</O:pThis test will try to assess the validity of this engine to make F3A and aerobatic flights, with airplanes that do not exceed five kilograms, observing and comparing their performance with experience of AXI 5330/F3A with that achieved very good results. <O:p</O:p
If results are successful we will replace this engine in our F3A models for the entire season including the 2009 World Championship in ffice:smarttags" /><ST1:place w:st="on"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com
><st1:City w:st=
Pombal</st1:City>, <st1:country-region w:st="on">Portugal</st1:country-region></ST1:place>.
(http://www.fpam.pt/WCF3A09/index.php)<O:p></O:p>
<O:p</O:p
Material: <O:p></O:p>
<O:p> </O:p><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shape id=_x0000_s1026 style="MARGIN-TOP: 47.1pt; Z-INDEX: 1; LEFT: 0px; MARGIN-LEFT: 162pt; WIDTH: 261pt; POSITION: absolute; HEIGHT: 158.15pt; TEXT-ALIGN: left" type="#_x0000_t75" stroked="t" strokeweight="1.5pt"><v:imagedata o:title="2- eeeee" src="file:///C:\Temp\msohtml1\01\clip_image001.jpg"></v:imagedata>ffice:word" /><?xml:namespace prefix = w ns = "urn:schemas-microsoft-com
><w:wrap type=
</w:wrap></v:shape>To perform this test we used two actual F3A models. Both are from Oxai, one of them used in 2007 season, Beryll. The other one, used in 2008 season getting our best results in national and international championships, the evolution of Beryll, Beryll EP, with negative dihedral and other evolutions. Both motorized with AXI 5330/F3A and Jeti Spin 99 with the following setup. In the other hand, to realise this test we used the new AXI 5325/24 with 85gr less than AXI 5330/F3A that we mounted in our airplanes to check this power and performance with the same setup and propeller, AXI 20x13 carbon. <O:p></O:p>
<O:p> </O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 border=1><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 432.2pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=576 colSpan=2>
Setup for Spin 99 and AXI 5330/F3A and AXI 5325/24<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Temp protection<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288><st1:metricconverter w:st="on" ProductID="100ᄎC">100ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Brake<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Manual setting<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Dead time<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>0.1s<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 4"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Initial brake<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>46%<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 5"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>End brake<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>66%<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Brake Speed<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>2.8s<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 7"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Timing<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>24º<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 8"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Frequency<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>8kHz<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 9"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Acceleration 0-100%<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>1.5s<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Number of cells<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>10<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 11"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>LiIo/po cut off/<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Volt per cell 3.2<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 12"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Off voltage set<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>31.95<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 13"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Cut off<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Slow down<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 14"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Initial point<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Auto<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 15"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>End point<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 16"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Throttle curve<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Linear ( edited by Rc-equipment )<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 17"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Rotation <O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Left<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 18; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=288>Timing Monitor<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 216.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=288>Off<O:p></O:p>
</TD></TR></TBODY></TABLE>
<O:p></O:p>​
<O:p></O:p>
Test:<O:p></O:p>
<O:p></O:p>
Nowadays we have done three tests with the engine and our airplanes with different batteries and different weather conditions to be sure of the proper functioning of the new AXI engine. <O:p></O:p>
<O:p> </O:p>
Test - 1 <O:p></O:p>
- Weather condition: 12-02-09 Temp: 10-<st1:metricconverter w:st="on" ProductID="13ᄎC">13ºC</st1:metricconverter> Wind: Calm9h - 10h a.m Humidity: 55% <O:p></O:p>
<v:shape id=_x0000_s1027 style="MARGIN-TOP: 9pt; Z-INDEX: 2; MARGIN-LEFT: 225pt; WIDTH: 198pt; POSITION: absolute; HEIGHT: 165.95pt" type="#_x0000_t75" stroked="t" strokeweight="1.5pt"><v:imagedata o:title="3- IMG_0521www" src="file:///C:\Temp\msohtml1\01\clip_image005.jpg"></v:imagedata><w:wrap type="square"></w:wrap></v:shape>Airplane:Beryll <O:p></O:p>
<O:p></O:p>
- Test flight. <O:p></O:p>
The first test flight was a quiet flight to verify that everything worked correctly. Once everything was in perfectly functioning we tried to realise some of P-09 and F-09 figures that need more engine performance and brake. We done the same tests with two different batteries and we recorded all the results that offer the Jeti 99 programming box. After flights, we checked the temperature of different parts, engine sounds and our outrunner subjection system.
<O:p></O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto 4.8pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext; mso-table-lspace: 7.05pt; mso-table-rspace: 7.05pt; mso-table-anchor-vertical: page; mso-table-anchor-horizontal: margin; mso-table-left: left; mso-table-top: 331.9pt" cellSpacing=0 cellPadding=0 align=left border=1><TBODY><TR style="HEIGHT: 37.7pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.7pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=195><O:p> </O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.7pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>RC MATERIAL 4800<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.7pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>FLIGHT POWER 5000<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>TEMP MAX<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="32ᄎC">32ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="31ᄎC">31ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>TEMP MIN<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="9ᄎC">9ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="13ᄎC">13ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 3"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>MAX CURRENT<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>48,7A / 32,9 V<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="53,1 A">53,1 A</st1:metricconverter> / 34,14<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 4"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>MIN CURRENT<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>42,1 / 33,8 v<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>45,6 / 34,33<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 5"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>MAX VOLT<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>41,82<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>41,74<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 6"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>ACTUAL VOLT<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>38,35 V<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>38,04<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 7"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>RUN TIME<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>6,59min<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>5,52min<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 8"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>POWER ON<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>8,44min<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>6,21min<O:p></O:p>
</TD></TR><TR style="HEIGHT: 19.35pt; mso-yfti-irow: 9"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 19.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>Motor pole<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 19.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>12<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 10"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>Gear<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>1 : 1<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 11"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>MAX RPM<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>7 150<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 12"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195><O:p> </O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><O:p> </O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 13"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>Engine Cowl Temp. <O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="38ᄎC">38ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="40ᄎC">40ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 14"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>Reels temp<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="71ᄎC">71ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="74ᄎC">74ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 15; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>Batteries Temp.<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="35ᄎC">35ºC</st1:metricconverter><O:p></O:p>
<O:p></O:p>
<O:p></O:p>
First test flight conclusion: <O:p></O:p>
<O:p></O:p>
<O:p></O:p>
After this three test flights we had very good feelings with this new engines. With calm wind the power was more than enough, the brake system was similar or better than AXI 5330/F3A because we take out 85gr of total weight. The temperature of the engine and batteries were perfect. The batteries were discharge equal or less but, with this test we could not draw final conclusions yet.
<O:p></O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto 4.8pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext; mso-table-lspace: 7.05pt; mso-table-rspace: 7.05pt; mso-table-anchor-vertical: paragraph; mso-table-anchor-horizontal: margin; mso-table-left: left; mso-table-top: 5.25pt" cellSpacing=0 cellPadding=0 align=left border=1><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=192><ST1:place w:st="on">Battery</ST1:place><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>RC-MATERIAL 4800<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>FLIGHT POWER 5000<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=192>Charge<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>2254 mAh<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>1925 mAh<O:p></O:p>
* We use the Thunder Power charger. <O:p></O:p>
To see the real functioning of the new AXI we needed to realise P-09 and F-09 to compare the discharge of this engines and the correct functionality. To do it, we mounted in our Beryll EP, the plane that we used in Italy in the F3A European Championships 2008, the new AXI 5325/24 to realise the second flight test.<O:p></O:p>
<O:p> </O:p>
Test - 2 <O:p></O:p>
- Weather conditions: 15-02-09 Temp: 09-<st1:metricconverter w:st="on" ProductID="10ᄎC">10ºC</st1:metricconverter> Wind: Calm 9h - 12h a.m Humidity: 38% <O:p></O:p>
<O:p></O:p>
Airplane: Beryll EP. <O:p></O:p>
Test flight: <O:p></O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto 4.8pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext; mso-table-lspace: 7.05pt; mso-table-rspace: 7.05pt; mso-table-anchor-vertical: page; mso-table-anchor-horizontal: margin; mso-table-left: left; mso-table-top: 529.9pt" cellSpacing=0 cellPadding=0 align=left border=1><TBODY><TR style="HEIGHT: 37.7pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.7pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=195>P-09 program<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="27ᄎC">27ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189><st1:metricconverter w:st="on" ProductID="7ᄎC">7ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>49,7A / 33,1 V<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>42.68<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>38,54 V<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>7,35min<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>7.20min<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>8,34min<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>8.27min<O:p></O:p>
</TD></TR><TR style="HEIGHT: 18.35pt; mso-yfti-irow: 11; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 146.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=195>MAX RPM<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 141.6pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 18.35pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=189>6740<O:p></O:p>
In the second test we realised seven flights with two P-09 and five experimental flights to test the engine in all positions and dangerous or critical figures in the semi-final program, F-09. The wind, like the first day, was in calm and the power was more than enough to do the entire P-09 program and enough to do the F-09 program that is a difficult and critical program for the pilot, airplane and engine.
<O:p></O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 border=1><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 158.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=211><O:p> </O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 135pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=180>RC-MATERIAL 4800<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185>FLIGHT POWER 5000<O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 158.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=211>Engine Cowl Temp. <O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 135pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=180><st1:metricconverter w:st="on" ProductID="38ᄎC">38ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="41ᄎC">41ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 158.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=211>Reels temp<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 135pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=180><st1:metricconverter w:st="on" ProductID="76ᄎC">76ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="80ᄎC">80ºC</st1:metricconverter><O:p></O:p>
</TD></TR><TR style="mso-yfti-irow: 3; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 158.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=211>Batteries Temp.<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="36ᄎC">36ºC</st1:metricconverter><O:p></O:p>
<v:shape id=_x0000_s1028 style="MARGIN-TOP: 15.2pt; Z-INDEX: 3; LEFT: 0px; MARGIN-LEFT: 108pt; WIDTH: 207pt; POSITION: absolute; HEIGHT: 164.85pt; TEXT-ALIGN: left; mso-position-horizontal-relative: text; mso-position-vertical-relative: text" type="#_x0000_t75" stroked="t" strokeweight="1.5pt"><v:imagedata o:title="5-IMG_0651eee" src="file:///C:\Temp\msohtml1\01\clip_image007.jpg"></v:imagedata><w:wrap type="square"></w:wrap></v:shape><O:p></O:p>
Second test flight conclusion: <O:p></O:p>
<O:p></O:p>
With this second day of tests we can saw the true potential of this engine realising the obligatory programs in a F3A event, the Preliminary schedule, P-09 and some of figures in the semi finial schedule, F-09, and the conclusion was very positive because the power of this engine is enough to realise all the F3A semi-final and final programs in the F3A competitions and for sure, the preliminary programs. For casual aerobatic flying, also perfect.
<O:p></O:p>
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto 4.8pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext; mso-table-lspace: 7.05pt; mso-table-rspace: 7.05pt; mso-table-anchor-vertical: paragraph; mso-table-anchor-horizontal: margin; mso-table-left: left; mso-table-top: 8.45pt" cellSpacing=0 cellPadding=0 align=left border=1><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" vAlign=top width=192><ST1:place w:st="on">Battery</ST1:place><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.05pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>2657 mAh<O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 144.1pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=192>2589 mAh<O:p></O:p>
<O:p> </O:p>
Test - 3<O:p></O:p>
<O:p> </O:p>Weather conditions: 18-02-09 Temp: 12-<st1:metricconverter w:st="on" ProductID="14ᄎC">14ºC</st1:metricconverter>
Wind: 20-<st1:metricconverter w:st="on" ProductID="25 km">25 km</st1:metricconverter> /h 10h - 13h a.m Humidity: 26%<O:p></O:p>
<O:p></O:p>
<O:p></O:p>
Finally, we found a strong windy day. The last of the tests necessary to verify that the engine can be used in F3A, is tested on a windy day. In many F3A competitions, we find this weather conditions and we need all the power and have great confidence in our engines. The results of the programming box were similar like test 2 and the temperature of the different parts were perfect. <O:p></O:p>
<O:p> </O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 135pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=180><st1:metricconverter w:st="on" ProductID="35ᄎC">35ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="37ᄎC">37ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 135pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=180><st1:metricconverter w:st="on" ProductID="69ᄎC">69ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="73ᄎC">73ºC</st1:metricconverter><O:p></O:p>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 138.8pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=185><st1:metricconverter w:st="on" ProductID="32ᄎC">32ºC</st1:metricconverter><O:p></O:p>
<O:p> </O:p>
Third test flight conclusion: <O:p></O:p>
<O:p></O:p>
The new AXI 5325/24 behaviour in this weather conditions after 6 flights was absolutely perfect. The power, like in the other tests, was more than enough and perfect to realise all the obligatory programmes. <O:p></O:p>
<O:p> </O:p>
<O:p> </O:p>Final Conclusion:<O:p></O:p>
<O:p></O:p>
The only problem detected of AXI 5330/F3A at the level of other electric engine competitors is their weight difference. After this test flights we can see that her weight loss has not affected a lot his necessary power in F3A. This work of weight reduction makes the new AXI 5325/24 can be a really serious option in the F3A competition market. <O:p></O:p>
To finally: <O:p></O:p>
- Thank you very much for trusting us to realise the tests of your new engine for F3A. <O:p></O:p>
- If you wish we will continue the test of durability. <O:p></O:p>
- We would like to continue the tests and for all the competition 2009 season included the World Championships ( where we represent AXI ) another two engines ( new AXI 5325/24 ) for our F3A planes. ( Two Berylls EP, and one Amethyst Biplane made from Oxai )<O:p></O:p>
<O:p> </O:p>
If you have any advice for the setup or maintenance we ask your help. Thanks. <O:p></O:p>
<O:p></O:p>
<O:p></O:p>
<O:p></O:p>
<O:p> </O:p>
By Joan Rombaut: <O:p></O:p>
<O:p> </O:p>
F3A <st1:country-region w:st="on"><ST1:place w:st="on">Spain</ST1:place></st1:country-region> Champion 2005 and 2008<O:p></O:p>
F3A Junior Second position in the European championships 2006 and 2008<O:p></O:p>
First pilot of Spain Team in the next World Championships in <ST1:place w:st="on"><st1:City w:st="on">Pombal</st1:City>, <st1:country-region w:st="on">Portugal</st1:country-region></ST1:place>. <O:p></O:p>
De accelleratietijd van 1,5 seconden is behoorlijk lang. Er zijn zelfs brandstof motoren die sneller zijn. Dat gaat je goed in de weg zitten bij snap-rolls. Van de Plettenberg Evo weet ik dat deze met de zelfde regelaar in slechts 0,2 seconden accellereert. Van de 5320 AXI serie weet ik dat deze ongelooflijk traag afgesteld moeten worden omdat ze anders uit de timing vallen, de 5330 kan veel sneller accellereren. De vraag is dus hoe traag is deze motor?
Vooral de snaps in het F09 zijn een probleem voor een trage motor, en dan vooral de 1,5 snap van meskant naar andere meskant omdat iedereen die met 1/2 gas aanvliegt om zo de snelheid niet te hoog laten worden. Na deze snap staat het model vrijwel stil en moet ogenblikkelijk het gas er op omdat het model anders in meskant wegzakt.
Ik weet niet waarom de bekende spaanse F3A piloot Rombaut de AXI 5325 alleen met een delay van 1,5 seconden heeft getest. Als 1,5 seconden absoluut noodzakelijk is om veilig te kunnen vliegen dan is het niet echt een goede motor. Je zal maar bij een stall turn net even een stootje gas nodig hebben......
Na een aantal slechte ervaringen met de 5320 in de SU 29 hebben we hier een 5330 ingebouwd welke beduidend sneller kan oppakken.
De beste motor is natuurlijk de Plettenberg EVO 30, de beste in prijs/kwaliteit is moeilijk, de Turnigy sk serie of de AXI 5330 of de 5325 met snellere axcelleratie of de.....kies maar...
Bedankt voor je antwoord Bert.
Ik had al gekozen voor de Axi 5330/F3A.
Natuurlijk liever een Plettenberg gehad (zeker i.v.m. de koeling), maar deze zijn zo prijzig. Bijkomend: Ik heb nog lang niet het niveau dat een dergelijke motor interessant is. :)
Groet,
Julius
