Topic gesloten
  • Topicstarter Topicstarter Santino23
dit is een zeer goeie regellaar voor in de magin one
NAVY CONTROL 570
High-performance speed controller with forward / stop functions, for 600...700 motors, or multi-motor models with 500...700 motors; also for high-performance power systems based on Pro, Sports and Ultra motors. Galvanic separation (OPTO) between motor and receiver power circuit prevents interference to the receiving system from brush sparking. The integral ´Rx-Filter´ active interference suppression system shields the receiver from motor interference and suppresses invalid signals. The high pulse frequency of 1000 Hz provides smooth motor starting to prevent damage. With power-on guard and thermal overload protection. Simple to adjust the speed controller using the ´eps´ easy programming system. With integral water cooling system for long operating times at high load currents. Can also be used without water cooling; in this case the stated maximum load current is not a continuous rating but limited to one ²000 mAh battery charge. Sealed with acrylic lacquer to protect from splash damage.
Specification:
Operating voltage: 8.4 - 36 Volts Weight: 66 g
Dimensions: 65 x 39 x 18.5 mm
more Specification:
With water cooling: 70 A
Without water cooling: 45 A
greetz jaimy
