oke de laatste vraag: de leverancier vertelde mij dat de auto nog in lipo mode gezet moet worden kan dit alleen nergens in het boekje vinden en ook op youtube niet te vinden wat word hier mee bedoelt ?
Staat echt in de handleiding zie pagina 16.
VXL-3s Battery Settings (Low-Voltage Detection Setting)
The Velineon VXL-3s electronic speed control is equipped with built-in
Low-Voltage Detection. The Low-Voltage Detection circuitry constantly
monitors the battery voltage. When the battery voltage begins to reach
the minimum recommended discharge voltage threshold for LiPo battery
packs, the VXL-3s will limit the power output to 50% throttle. When the
battery voltage attempts to fall below the minimum threshold, the VXL-3s
will shut down all motor output. The LED on the speed control will slowly
blink red, indicating a low voltage shutdown. The VXL-3s will stay in this
mode until a fully charged battery is connected.
Your model includes a Power Cell NiMH battery. The VXL-3s speed control’s
Low Voltage Detection has been disabled for best performance with
this battery. The speed control’s LED will glow red when it is turned on,
indicating Low Voltage Detection is disabled. Be certain to activate Low-
Voltage Detection if you install LiPo batteries in your model. Never use LiPo
batteries while Low-Voltage Detection is disabled.
Verify that Low-Voltage Detection is DISABLED:
1. Turn on the transmitter (with the throttle at neutral).
2. Connect a fully charged battery pack to the VXL-3s.
3. Press and release the EZ-Set button to turn the VXL-3s on. If the LED is solid
red, then the Low-Voltage Detection is DISABLED (not safe to use LiPo
batteries). If the LED is solid green, then Low-Voltage Detection is ACTIVATED.
To activate Low-Voltage Detection (LiPo setting):
1. Make sure the LED on the VXL-3s is on and red.
2. Press and hold the EZ-Set button for ten seconds.
The LED will turn off and then light green. Also, a
“rising” musical tone will be emitted from the motor.
3. Low-Voltage Detection is now ACTIVATED.
To disable Low-Voltage Detection (NiMH setting):
1. Make sure the LED on the VXL-3s is on and green.
The LED will turn off and then light red. Also, a
“falling” musical tone will be emitted from the motor.
3. Low-Voltage Detection is now DISABLED.
