Traxxas Slash 4x4 VXL Topic.
Discussie in 'Electro offroad' gestart door diver, 10 okt 2009.
Topicstatus:
  1. diver
    diver
    28 apr 2009
    Schijndel
    Slash 4x4
    Traxxas Part #6808
    Introductory tour:
    http://www.traxxas.com/products/elec...r/default.html
    Slash 4X4 VIDEOS:
    http://www.traxxas.com/products/elec...#/portfolio-08
    • Single Velineon 3500 system with VXL-3s ESC
    • Motor is longitudinally-mounted with a center driveshaft
    • Chassis layout is step-style, like the 2WD with a raised center, large wide high tub
    • 2.4Ghz 2ch transmitter & 4ch receiver included
    • Revo differentials
    • Plastic driveshafts
    • Metal turnbuckles
    • Ships with a 7cell pack for 40mph speeds
    • Rated for 60mph with a 3S lipo
    • Waterproof electronics
    • Accepts all standard Slash bodies
    • Designed & tested to accept the Castle Mamba Monster motor system without drivetrain upgrades
    • New spring rates
    Maximum Traction
    • Slash 4x4 delivers handling and conrol just like a full-size Pro 4X4 Short Course race truck The full-time 4WD system harnesses the power of the Velineon system and puts it to the ground at all four corners Drive harder, brake later, corner deeper. Hammer the throttle and power out of the turns with four-wheel-drive grip. Simply put, the Slash 4X4 is made for aggressive driving.
    Superior Efficiency, Integrated Design
    • Slash 4X4 uses just three gear meshes to drive all four wheels, eliminating the need for a multi-gear transmission. The highly efficient drivetrains pins effortlessly on rubber-sealed ball bearings, and is integrated seamlessly into Slash 4X4's unique chassis for optimum performance and easy maintenance. Slash 4X4 raises 4WD to a new level of spimplicity, performance, and convenience.
    Extruded Aluminum Driveshaft
    • Slash 4X4's center driveshaft is formed from extruded aluminum. There are no dogbones to wear, no drive cups to obble. The extrusion process allows the shaft to be hollow and lightweight with internal splines that fit directly and securely onto the input shafts of the front and rear drive assemblies. The shaft runs perfectly straight and true and offers superior durability. Traxxas engineers highlighted this important innovation with vivid blue anodizing and a laser-etched Traxxas logo
    Single-screw motor access
    • Inspired by the innovative E-Revo, Slash 4X4 features a unique motor mount that holds the Velineon 3500 motor securely yet releases instantly with just one screw. Gear-mesh adjustments are fast and easy and the motor can be removed in just seconds.
    Revo-spec Differentials
    • Race-proven in the 7-time National Champion Revo, Slash 4X4's differentials represent the state of the art in power handling and efficiency. Precision silicone gaskets and X-ring seals allow the diffs to be tuned for specific running conditions by varying the viscosity of the fluid inside them.
    Easy Access
    • Diff access for tuning is quick & easy. Just remove the front or rear cover and the entire diff slides right out. The Slash 4x4 lets you focus on having fun at the track instead of being chained to the workbench scrambling through complex assemblies.
    New heavy-duty driveshafts
    • Slash 4x4's telescoping, u-joint driveshafts may look familiar but they have evolved for increased strength & articulation. Traxxas U-joint shafts allow for maximum suspension movement resulting in longer travel and tighter turning. Extra material & design tweaks greatly increase torque handling. The shafts can even be used to upgrade Slash and other Traxxas models!
    Torque-Control (TM) Slipper Clutch
    • Another Traxxas exclusive, Slash 4X4's patented slipper clutch design uses special semi-metallic friction material and finned aluminum alloy pressure plates to dissipate heat and provide consistent traction control. The slipper is easily adjusted without disassembly or removal, and the unique 3-pad design is proven rugged in Traxxas' most powerful electric and nitro vehicles. It's the perfect complement to Velineon brushless power and 4WD, offering the ultimate in traction control
    Built for Brushless
    • Extreme BL horsepower is never an afterthought at Traxxas. The Slash 4X4 driveline is built to handle power for today and accommodate future power upgrades down the road. The spur gear features rugged 0.8 module / 32-pitch teeth for total reliability no matter how much power you pour on.
    How tough is it?
    • Slash 4X4's chassis is designed to allow the massive Mamba Monster power system -- which normally motivates trucks twice the weight of the Slash 4X4 -- to simply drop right in with virtually no modification. Overkill? Perhaps, but we couldn't resist going 80+ mph. We don't think yuo will resist either, so the drivetrain is built to handle the horsepower and speed.
    Tuning Precision
    • Advanced CAD allowed engineers to precisely pinpoint a range of suspension tuning adjustments to tune the performance for different track conditions. Caster, camber, toe, and roll center are all easily adjustable.
    All-New C-Hub Design
    • The fully-optimized front axle carrier is a result of computer modelling that allowed engineers to design for maximum articulation without binding or interference Tight steering response is always there, even at the extreme ranges of the suspension travel. Double-shear tie rods and camber links simply can't pop off, so you always stay in control. Robust construction wards off crash damage, and oversized 10x15mm inboard bearings and 5x11mm outboard bearings are incredibly durable and smooth.
    All-New Steering
    No part of the Slash 4X4 was overlooked in the quest for durability, precision, and performance The new dual-bellcrank design pivots on rubber-sealed ball bearings for smooth action in the harshest conditions, and an integrated cam-type servo saver protects the gears from crash impacts without sacrificing steering precision.
    Officially-licensed BFGoodrich Mud-Terrain T/A tires
    • The Slash 4X4 is the first to wear fully-licensed Mud-Terrain T/A tires, proven performers in TORC Series competition. For the Slash 4X4, the distinctive design has been realistically captured in high-grip rubber, complete with white sidewall lettering.
    • Offering equal parts style and strength, the Slash 4X4's wheels feature a new SCT Split Spoke design with a mirror-chrome center and color-molded (imitation) "beadlock" style detail for a realistic look. Fully compatible with factory Traxxas and aftermarket tires, the new wheels also feature 12mm hexes and the same offset as Slash 2WD rear wheels.
    OPTIONAL ACCESSORIES
    Available separately:
    • Center differential - sealed, tunable
    • Aluminum C-hubs
    • Aluminum steering blocks
    • Aluminum rear hub carriers (same as the Rustler)
    • Steel CV shafts with rubber boots & captive u-joint pins
    • Front & rear sway bar set
    • Aluminum shock towers
    • Aluminum motor mounting plate
    • Amuminum motor mount
    • Castle Creations Mamba Monster 2200Kv 6S system for speeds beyond 80mph, includes custom ESC mounting bracket and 5mm pinion
    • Revo torque control slipper clutch -- same design as stock, but with 40% greater surface area for increased heat dissipation and holding power for high-powered brushless setups
    • Clear plastic gear cover
    • Traxxas RC Hero camera mounting bracket
    • Velineon cooling fan
    • Big Bore aluminum shocks (same as the Slash set)
    • Battery expansion kit, allows taller packs, dual 7-cell NiMHs, or 6S lipo
    En nu nog wachten tot we de eerste in NL hebben
    Laatst bewerkt: 11 okt 2009
  2. Byte
    Byte
    20 dec 2007
    Venlo, Nederland
    Eerste vraagje alvast... wanneer is hij leverbaar in de USA?
  3. Psygho (Emil)
    Psygho (Emil) Forum veteraan
    7 jan 2004
    Prov. Drenthe.
    Even de topic tittel aangepast, zat een typo in ;)
    Ontopic:
    Het lijkt me dat deze kwetsbaarder is dan de ouwe slash,vanwege de ophanging aan de voor en achterkant. De verbinding van de bodemplaat naar de aandrijving zeg maar...
    Maar goed als je hem enkel gebruikt waarvoor hij bedoelt is, zal het meevallen...
    Je moet ook niet de halfpipe jumps maken met een slash...
  4. Nard Cox
    Nard Cox Forum veteraan
    23 jan 2009
    Ben echt benieuwd naar mods van deze wagen. Met wat bredere armen en driveshafts, kleinere bumpers en andere body en eventueel nog offset wielen voor extra breedte kan dit een leuke 4WD Rustler worden, lol.
    Complimenten op de startpost!
  5. diver
    diver
    28 apr 2009
    Schijndel
    bedankt voor het aanpassen tis al laat
    ja het lijken maar 2 boutjes te zijn maar dat kan ik me niet voorstellen!!
  6. Riko
    Riko
    6 aug 2009
    stroppendrager, Belgiƫ
    er zijn dus 4 schroeven voor en 4 schroeven achter he voor alle duidelijkheid, 8 in totaal he ;) (die de voor en achter ophanging aan het chassis vastmaken)
  7. SCRT Pilot
    SCRT Pilot Guest
    De bevestiging zit wel goed denk ik, door de skid plates worden er voor en achter driehoeken gevormd welke ontzettend stijf zijn. Haal de skid plates maar eens van de 2WD slash en het is slappe was, me de skid plates erop is het gewoon stijf.
    Je moet ook niet zonder de skid plates rijden, die dingen hebben meer functies dan alleen maar glijden.
    Laatst bewerkt door een moderator: 11 okt 2009
  8. vonkentrekker
    vonkentrekker
    7 feb 2009
    Maastricht Airport.
    Haha geweldig, hij is nog niet leverbaar maar we zijn al aan het upgraden :cool: :D :D
    Ik had gisteren ook het idee om een topic te openen, maar niet zo mooi als "diver" gedaan heeft, complimenten.
    Ben zeer benieuwd wanneer er geleverd kan gaan worden, hopelijk niet zoals bij de 1/16......iedere keer een maandje later...
    En dan nog wachten dat ie eindelijk ook in europa / nederland geleverd wordt.
    Bijna had ik een 2WD slash erbij gekocht, nu wacht ik toch nog maar heel eventjes..........
  9. mixit
    mixit Guest
    En hoeveel meot hij kosten ?
  10. RFAC
    RFAC
    5 aug 2004
    Den Helder
    ik geloof dat hij rond de 400 Dollar zal gaan kosten...
  11. Onder 400 dollar. Hij staat op 1 amerikaanse website genoemd voor 399.99 dollar. Anderen zullen er nog wel iets onder gaan.
    Wel jammer dat het inclusief lader en een 8,4 volt 3000mAh accu is. Straks doen ze er ook nog 8 alkaline penlites bij voor de zender :-S
  12. mixit
    mixit Guest
    400 dollar voor de VXL ?
    Met accu en lader. Dat is niet duur.
    280 euro ongeveer, dat betaal je voor een 2 wd slash zonder brushless met lader enz. :eek:
  13. Lochii
    Lochii
    14 apr 2009
    Het land van Maas en Waal
    Daarom. De dollar prijs zal hier wel weer de euro prijs worden.
    Ik vind de 4wd slash opzich wel een gaaf concept, maar ik blijf toch bij mijn vertrouwde 2wd.
  14. danny56
    danny56 verslagschrijvers
    5 sep 2009
    Leeuwarden
    Is dit nu het 1-10 of 1-16 model?
  15. Joris R.
    Joris R. Guest
    1/10. Waarom zit er nu trouwens al een accu en lader bij? Beetje jammer eigenlijk.
  16. Riko
    Riko
    6 aug 2009
    rare vraag, sinds de 1/16 4x4 slash al maanden, of zelfs al meer of een jaar te koop is.......
  17. diver
    diver
    28 apr 2009
    Schijndel
    kan iemand in de toppic naam zetten dat het om de 1:10 gaat krijgen we daar geen gezeur over!!!!
  18. SCRT Pilot
    SCRT Pilot Guest
    Ja, dat kun jij zelf als het goed is.
  19. vonkentrekker
    vonkentrekker
    7 feb 2009
    Maastricht Airport.
    Tsjaa, is ook "jammer" dat er een 2.4 GHz zender bij zit :rolleyes:
    Maar bekijk het van marketing oogpunt,
    je wilt een populaire wagen op de markt zetten waar veel hobby rijders -voornamelijk beginners dus- warm van lopen.
    En wat is dan belangrijk boven de duurzaamhieid?
    Juist de prijs.
    Het is dus proberen om zo'n groot mogelijke groep te bereiken tegen een goede prijs.
    Volgens mij is dat bij Traxxas goed gelukt :worship:
  20. Joris R.
    Joris R. Guest
    Ik snap je punt. De prijs is ook niet hoog voor zo'n leuke wagen.
    Maar waarom zou het jammer zijn dat er een 2.4GHz zender bij zit? Da's toch juist beter?
Topicstatus:
