traxxas villain ex
Hull Type Offshore Deep "V"
Dead Rise Angle 24 Degrees
Hull Length 31 Inches (787mm)
Beam 8.25 Inches (209mm)
Weight 56oz (1.587kg)
Draft 4.5 Inches (114mm)
Speed Control Type EVX-2 Marine ESC
Motor (electric) Twin Titan® 550 Marine
Drive System 2:1 Gear Reduction Drive
Outdrive Adjustable Surface-Piercing
Speed Control Features:
* 14.4 Volts of Power
* Microprocessor Controlled
* Traxxas High-Current Connectors
* EZ-Set® Push-Button Set-Up
* Thermal Shutdown Protection
* For Traxxas Villain EX and Others!
traxxas villain
Weight 59oz (1.685kg)
Speed Control Type XL-10™ Marine ESC
Motor (electric) Twin 540 Stingers™ (20-Turn)
• One-button setup
• Water-cooled heat exchanger
• Thermal shutdown protection
• Uses a single, economical 7.2V 6-cell battery pack
• 3 user-selectable, pre-programmed drive profiles
• High-frequency operation for smooth throttle control
• Efficient, low-loss design for longer run times
• Backed by the Traxxas lifetime electronics warranty
rompen zijn het zelfde
het verschil zit hem in de accu en motoren
