Turnigy Brushless ESC 85A w/ 5A SBEC probleem
Hier gaat het om Turnigy Brushless ESC 85A w/ 5A SBEC
Built with imported N-Channel mosFETs and an ultra fast Atmel MCU & heartbeat make this a high performance ESC with excellent sync capabilities. This ESC has a 5A SBEC for solid reliable servo power.
Programmable via an R/C controller.It allows you to program all functions to fit your specific needs, which makes it efficient and user friendly.
Features:
Extremely low internal resistance
Super smooth and accurate throttle linearity
Over heat and over-load protection
Auto shut down when signal is lost or radio interference becomes severe for more than 2 seconds
Supports high RPM motors
Power arming protection (prevents the motor from accidentally running when switched ON)
New Advanced programming software
Programming features:
Brake setting (we recommend using brake for only folding props applications)
Battery type(LiPo or NiCd/NiMh)
Low voltage cutoff setting
Factory default setup restore
Timing settings (to enhance ESC efficiency and smoothness)
Soft acceleration start ups (for delicate gearbox and helicopter applications)
Governor mode(for helicopter applications)
Motor rotation( clockwise\counterclockwise)
Switching frequency
Low voltage cutoff type (power reduction orirnmediate shutdown)
Factory default settings:
Brake: off
Battery type Detect: LiPo with Automatic Cell
Low voltage cutoff threshold: Medium (3.0V/65%)
Timing setup: Automatic
Soft Acceleration Start Up: Medium
Governor mode : OFF
Frequency : 8kHz
Low voltage cutoff type: Reduce power
Spec.
Cont. Current: 85A
Burst Current: 100A
Battery: 2-6 Cell Lipo / 5-18 Cell Ni-XX
SBEC: 5.5V/ 5A Output
Weight: 60g
WAT is het probleem.
Als ik mijn hkt6 v2 ontvanger koppel aan de regelaar gebeurt er niks.
(in kanaal 3)
Met mijn andere regelaar gaat de ontvanger aan.
Met een aparte stroom toevoer aan de ontvanger werk alles wel.
Nu heb ik de spanning gemeten op servo draad van de regelaar en staat er 4,8 volt op de 2 buitenste pootjes zwart en oranje.
Als ik die zelfde meting doe bij mij andere regelaar staat er 5volt op de zwarte en witte draad (2 pootjes naast elkaar.)
en hier doet de ontvanger het wel mee.
is mijn probleem zo duidelijk... haha
grt jarno
Ik heb precies dezelfde
maar heb het probleem niet
het zou kunnen dat ze wat draadjes verkeerd aangesloten hebben in de schakelaar
het blijven kinderen
meet je wel op de juiste draden?
Wat ik op de foto zie zou ik verwachten dat de bruine draad negatief is en rood positief. Meestal is wit of oranje de pulsdraad.
De puls draad zal wellicht een pull-up weerstand hebben, waardoor je best 5v erop kunt meten.
Bec kan inderdaad kapot zijn, zou wel jammer zijn.
Oranje is idd de pulsdraad, deze fiches kun je ook andersom ook steken (verkeerd dus) en dan gebeurt er niets.
Stevo
De pulse draad en de + zitten dan verkeerd om.
Deze omgewisseld en nog geen verbetering.
Nu de spanning gemeten terwijl de stekker in de ontvanger zit en aanstaat.
1,4 volt hou ik over. dus mij lijkt het dat de bec in de regelaar kapot is ...?
Jahrno ik ben toch heel beniewd om een foto te zien met een pijltje waar je meet.
Ik zou het namelijk nogal heeeel slecht vinden als op de regelaar de pulse en de plus draad verwisseld zijn
Normaal is altijd buitenkant wit/oranje de puls dan in het midden de rode draad de plus en buitenkant zwart of bruin als min.
Dus nu zit de pulsdraad in het midden, de + aan de ene kant, en de - aan de andere kant?
zoals Danny zei, een fototje kan duidelijkheid brengen...
Ik gebruik alleen de ecs en de ontvanger.
Ecs heeft een aan/uit schakelaar.
Ik doe de lipo eraan en de schakelaar op ON. (dus nog zonder ontvanger)
Dan meet ik over de bruine en oranje draad 4,8 volt.
Op de bruine en rode draad niks.
Nu met de ontvanger aangesloten en de oranje draad op de plek van de rode.
Valt de spanning terug tot 1,4 volt.
Zet voor de grap eens de schakelaar op off en meet dan eens op de bruine en rode draad. Kan zijn dathet dekseltje op de schakelaar verkeerd om zit en dus on en off omgewisseld zijn.
Ik denk dat je er ondertussen vanuit kunt gaan dat de bec defect is.
Zet de pulsdraad wel weer aan de buitenkant als je hem wilt gaan gebruiken.
Ik weet echter niet of er nadelige gevolgen kunnen zijn als de bec defect is. Misschien rode draad weghalen?
Waar komt de voeding van de ESC electronica vandaan, staat dat los van de bec?
