This year it will be the 11th edition of the Vest Pokal. After 2013 it will be the second time run as the German Open F3K. It is also part of the Contest Eurotour, the FAI World Cup and is the first qualifying event for the german national team 2019.
The online registration will start next week. I'll inform you in this thread when the registration is open.
The biggest change in terms of rules and regulations is the mandatory labelling for model aircrafts in Germany. The owner of a model airplane or of an unmanned aerial system, each with a take-off mass of more than 0.25 kilograms, must place his name and address visible in a permanent and fire-resistant lettering on the aircraft before first-time operation. I think the competitors from previous years will agree, that chances are quite high, that we will have weather conditions requiring models with a flying weight of more than 250g. So you better prepare, as will have to check this.
Here is the interpretation of visible, permanent and fire resistant we use at our field:
visible - visible from the outside without the need to take of a cover (i.e. canopy). Behind a clear transparent servo cover would be ok.
permanent - glued, screwed or riveted to the model. Hook an loop tape is not permanent.
fire resistent - aluminium or other metal. Paper or Foil is not ok.
Here are some sources for metal shields:
http://shop.vth.de/modellbauzubehor/...ein-5-stk.html
https://www.shop.deutscher-modellfli...05&t=3&c=6&p=6
If you need help sourcing the labels send a message to vestpokal (at) web.de
See you in Herten!
Cheers
Ulrich
See you in Herten!
Cheers
Ulrich
