Heb deze al jaar of twee liggen, word is tijd om er mee te leren vliegen , na mn eerste vlucht waar een maat de body beschadigde , nu heb ik er ene gevonden zodat de body weer kraaknieuw is de lengte is ongeveer 70cm
WALKERA 59DQ 6CH Double Brushless Metal Upgrade Helicopter RTF - 2.4GHz
Features:
CCPM mixing control system and collective pitch control system make perfect 3D maneuvers such as rolls, inverted,and swoop flights
The compact structure characterized by metal main frame and metal tail boom makes the helicopter more stable.Easy-to-be mounted parts like servo are used
380PF brushed motors as drive are powerful and make you fly with much more enjoyment
The flight time on the saturated Li-Po battery will be up to 6-8 minutes, depending on your flight
The usage of 2.4G technology is prompter in reaction, more sensitive in operation, and stronger in anti-interference
Specification:
Tail Motor Type: WK-WS-20-003(Brushless)
Servo: weight 8.5g;speed 0.11sec/60°(4.8V);torque 0.9kg/cm (4.8V) Dimension: 22.5 * 11.5 * 24mm
Receiver: RX-2606
Gyro: Built-in
All-up Weight: 643g (Battery included)
Transmitter: WK-2602
Main Motor Type: WK-WS-26-006
Tail Rotor Dia.: 136mm
Main Rotor Dia.: 630mm
Battery: 11.1V 1500mAh Li-Po
Overall Length: 650mm
ESC: WK-WST-30A
deze is uit het gamma van walkera maar er zijn nog volop stukken te verkrijgen ervoor
de volledige set
de staartrotor en rotor
de aparte romp moeilijk te vinden maar heb ze nu
Features:
Specification:
Receiver: RX-2606
Gyro: Built-in
ESC: WK-WST-30A
de volledige set
