V
volle yoghurt
heej wat vinden jullie van deze setup?
Align T-Rex 600CF w/CF Frame,motor,ESC,BEC KIT
Focus Shot1(High precision main rotor assembly)
Focus Shot2(Tail rotor assembly with double bearings)
Focus Shot3(New-sturdy lightweight main frame)
Focus Shot4(Standard landing skid and 3D landing skid)
Focus Shot5(Fiberglass canopy)
Focus Shot6(Sticker)
Focus Shot7(600L Brushless motor)
Focus Shot8(RCE-BL75G Electronic speed controller)
Focus Shot9(REC-B3X External BEC)
Focus Shot10(Li-Polymer 7.4V 1100mAh 9C)
Instructions: Specification:
?CF Frame Combo Version?
?Features
1.Electric Power System
2.Carbon Fiber Frame
3.Pre-Painted Fiberglass Canopy
4.Carbon Fiber Tail Blades
5.Triple-Bearing Block Main Shaft Support
6.Fully Driven Tail Auto Rotation System
7.Tail Rotor Drive Belt System
8.Push-Pull Control Linkage
9.Rear Tail Servo Mount
10.10mm Hollow Main Shaft, 8mm Spindle
Specification:
?Length:1200mm(47.25 in)
?Height:388/405mm(15.25 in/16 in)
?Main Blade Length:600mm
?Main Rotor Diameter:1350mm(53.15 in)
?Tail Rotor:240mm(9.45 in)
?Motor Drive Gear:10T(11T optional)
?Main Drive Gear:170T
?Autorotation Tail Drive Gear:180T
?Tail Drive Gear:40T
?Drive Gear Ratio:1:17.0:4.5/1:15.45:4.5
?Weight(w/o main blade):1340g
?Flying Weight:Approx 3000g(6.6 lbs)
Accessories:
?T-REX 600(CF) Kits SetX1 set(w/o main blade)
?Fiberglass CanopyX1
?StickerX1
?Standard Landing SkidX1
?3D Landing SkidX1
?RCM-BL75G 75A Brushless ESC(Govener Mode)X1
?600L Brushless motorX1
?REC-B3X External BECX1
?5.1V Step-Down Voltage RegulatorX1
?Li-Polymer 7.4V 1100mAh 9C For BECX1
599,00 euro
?Features
Specification:
Accessories:
?StickerX1
?3D Landing SkidX1
599,00 euro
