Voorstellen uit Denemarken
Denmark is proposing a number of new tasks for F3K together with a deletion associated to the proposal of “4 x 2½ minutes”, for the CIAM meeting next spring (2010).
General reason for the proposal of new tasks
More and more contest have numerous rounds, and more tasks would make it easier to choose task to harden the competition, and separate the top pilots.
More tasks will increase the demand for an even wider tactical horizon
General reason for varying working times
The working time doesn’t always have to be 10 minutes. A longer working time gives the possibility for more thermal cycles to pass through in one groups working time, together with the associated sink.
Varying working times are not new to F3K (se 5.7.11.1 task A (last flight) – working time min 7 minutes, max 10 minutes).
New task 4 x 2½
Each competitor has an unlimited number of flights. Only the best four flights will be added together. The maximum accounted single flight is 150 seconds.
Working time is 10 minutes.
(If this new task is chosen, it would be natural to delete task G (5.7.11.7)
Reasons
The task G (5.7.11.7) has changed to a turnaround task for the good pilots, instead of the original duration task. Therefore an increased max time will push the demand more in the direction of air reading, instead of precise timing.
Data
This task has been flown two years ago in “Swinging Denmark F3K”. Se this link for Martin Kopplows comments on the task:
http://www.modelflyvning.dk/media/92109/mal%20ein%20kurzer%20bericht%20vom%20wochenende.do c
It was also flown in 2009 as round zero.
Delete task G
In case the proposal of a new task (4 times 2½ minutes) is not voted for, please disregard this proposal
New task - 4 x 3 minutes
Each competitor has an unlimited number of flights. Only the best four flights will be added together. The maximum accounted single flight is 180 seconds.
Working time is 12 minutes.
New task - 3 x 3 minutes
Each competitor has an unlimited number of flights. Only the best three flights will be added together. The maximum accounted single flight is 180 seconds.
Working time is 9 minutes.
New task - 5 x 3 minutes
Each competitor has an unlimited number of flights. Only the best five flights will be added together. The maximum accounted single flight is 180 seconds.
Working time is 15 minutes.
New task - 3 x 4 minutes
Each competitor has an unlimited number of flights. Only the best three flights will be added together. The maximum accounted single flight is 240 seconds.
New task - 3 x 5 minutes
Each competitor has an unlimited number of flights. Only the best three flights will be added together. The maximum accounted single flight is 300 seconds.
New task - three last flights count
Each competitor has an unlimited number of flights, but only the three last flights will be scored.
Maximum time per flight is 180 seconds for 10 minutes working time.
Example: 1st flight 150 s
2nd flight 45 s
3rd flight 180 s
4th flight 150 s
Total score: 45 s + 180 s + 150 s = 375 s
Also posted here:
http://www.rcgroups.com/forums/showthread.php?t=1132815
and
Proposal of additional tasks for F3K, from Denmark - RC-Network
Erik Dahl Christensen
Denmark
Erik Dahl Christensen / "The Bart Bird man" aka Dr. Dahl / Holstebro mfk. / http://www.gliders.dk / www.swdk.dk /
En stor ros til bestyrelse og andre aktive - I gør det godt!
een geweldig goed idee om veel nieuwe taken te introduceren. Hoe meer taken er zijn hoe kleiner de kans op "Poker" en "Oplopend"!!
Bas
wat is poker en oplopend ?
Sorry, ik ben niet op de hoogte hoe het verloop is in een f3k wedstrijd, maar de taken an sich klinken me heel goed in de oren.
Bas
Het is mij duidelijk dat jij goed hebt opgelet bij kansberekening destijds op school. Dat mis ik nog wel eens bij anderen................
Loet
They are made as sepperate proposals, but I have joined them to save space. Each highlitened sentence is a single sepperate proposal
Hallo,
Zal ik dit ter sprake brengen op de vergadering van de VML en de waalse tegenhanger ervan in Belgie? Op 6/11 hebben we een vergadering en ikzelf ga waarschijnlijk de verantwoordelijkheid nemen voor F3K in vlaanderen.
Groeten,
Johan
