Ze maken ook alles na in HK
voor
$203.51US heb je hem thuis mits geen kosten aan de deur!!!
1/10th Brushless 4WD Short Course Truck
Hit the dirt hard with Brushless 4WD Power! The Turnigy 1/10 Brushless 4WD Short Course Truck comes pre-assembled and includes a 3s1p 2200MAH battery and charger that will have you ready to roost the competition in no time! All you will need is a receiver and transmitter. The
ESC is equipped with a cooling fan and is ready to handle 2s to 3s Lipo.
The aluminum motor mount includes cooling fins and a solid clamp style mounting system to ensure your truck will handle the ruff stuff and keep coming back for more. The heavy duty metal drive shaft will keep putting the power down to the large 110mm short course truck tyres. The Truck features fully adjustable suspension and oil filed shocks to fine tune the ride to the conditions of your favorite track or bashing spot. An innovative and adjustable battery compartment will accommodate a variety of different packs.
Spec.
Motor Size: 3650 Brushless inrunner
Motor KV: 2080KV
ESC: 35A EZ-Run (with Reverse)
Battery: 3s 2200MAH LiPo included
Charger: Lipo Balance charger included
Battery compartment: (140x50x50mm MAX SIZE)
Servo: High-Torque Steering Servo
Traction: Full Time 4WD, Twin Diff
Length: 550mm
Width: 310mm
Height: 190mm
Ground Clearance: 28~42mm Adjustable
Required.
Radio System (
Rx/
Tx)
