Nieuwe regelaars van MGM: X-SERIES programmable brushless speed controllers for all types of models | X-SERIES | Brushless Spe | MGM Compro - Electronics for Models
Zitten hele mooie features op vind ik zelf:
NEW features of the X-SERIES controllers:
Further advantages X-SERIES controllers:
- The controllers use new and very powerful 32 bit processors, which have enough throughput to satisfy all requirements and demands. That is also one of the reasons that these controllers have features and possibilities not achievable with simple controllers using 8-bit or even 16-bit processors.
- Controllers offer up to 400A / 63V (= 15 Lipol), that is up to 25kW!
- Choice of the model type (airplane, car, boat, heli – all in one) depends only on your controller settings, and both unidirectional as well as bidirectional operation is enabled (except for heli)
- Controllers have 4 memory banks for parameter settings (enables 4 different settings for 4 different modeles of any type according to user preferences (car, boat, airplane, heli...)) choice of one of the 4 preset models is thus very easy
- Internal Black Box (logging device) is integrated into the controller (no additional cables needed, no additional cost)
- the controllers can make use of "back data channel" (telemetry) - real time telemetric data transfer from the model) of some RC sets (such as TWIN by MZK servis) and can therefore send all the measured values to the transmitter in real time (to a display unit connected to the transmitter)
- Controllers making use of the back channel have two servocables (one for control of the controller, second for the data transmission to the receiver) - it is also a great advantage that feeding of the receiver and servos is doubled in this case, higher safety and smaller losses on the resistors of the servocable and its connector
- Very clear indication of different states of the controller using 4 LED
- When connected to PC, both saved data as well as warning and error notifications are transferred from the controller to the PC
- Controller can send all the measured (logged) values into PC in real time
- It is possible to reduce power for both reverse as well as forward gear (current reduction to preset value)
- Powerful switched S-BEC, with choice of 5V and 6V or 5V, 6V, 7V and 8V (version HV-BEC), currents up to 6A
- For controllers up to 35V (i.e. up to 8 Lipol cells) is possible to choose BEC or opto coupling (OPTO version) in order
- Parallel to BEC is possible connect battery, significantly increase safety and reliability all RC system
- Extremely fine throttle step 2048 values (steps)
- Very high maximal motor revolutions (up to 250 000 rpm for a 2 pole motor)
- Automatic sensor setting when sensor motors are connected, the problematic "phasing" of sensors and phases on motor is therefore not needed, the sensor position is also optimized, it is possible to connect also other motors not just those recommended by EFRA
- Sensor motor controllers (marking SE) you can run with sensorless motors also - necessary only set correct motor type to parameters
- very transparent and easy settings of parameters using PC with Windows (XP, Vista, 7)
- you can update the controller with a newer firmware yourself from our website, using your PC, USBCOM_4 module and CC_11 cable. This new feature is very useful and favorable. Controller may have additional features that were not available at the time of purchase. You may have actual version at all times. The same components will be used to set parameters and read-out of data from the controller.
- controllers also support motors requiring higher working frequency of 32kHz (such as "Tango" motor by Kontronik etc.)
- controllers support NiCd, NiMH, Lipol, Li-Ion, A123, acid (Pb) cells and possibly any other new battery type (universal settings) which may have not even existed at the time of the controller production
- unmatched protection and management of accumulators Lipol / Li-Ion (for these cell types this is of a fundamental importance) as well as A123 cells and NiCd / NiMH
- very smooth starts with sensor as well as sensorless motors
- Possibility to connect brake lights or flashing beacon
- They are standard manufacture in a version with a switch (in a safe connection - as in all MGM compro controllers, damage of switch does not affect controller)
- it is possible to choose from several variants and cooling with active cooling and water cooling
- it is possible to choose a variant with enhanced resistance to water and humidity (marked as WP) or with a 100% water resistance (marked as WR)
