Apollo van Hobbyking DLG or not DLG
Het lijkt erop dat er alleen wat gelcoat verdwenen is.
Dit is wer glad te maken met (ingedikte en evt. gekleurde) (lamineer-)epoxy.
Maar controleer goed of het glasvezel nog wel heel is.
Value Hobby Apollo - RC Groups
I bought one of these with the idea of trying out DLG on the cheap in $$ and time spent building. The quality of the plane is pretty good, good instruction manual and good, complete hardware package. Assembly went well and everything fit pretty well. One problem was that the rear wing joiner rod had no tube installed in the wing,only a hole through the balsa wing root rib.
When I put it on the scale the problems began. RTF weight was 16.5 OZ with 9G servos, micro receiver & 2S Lipo- Very heavy. The wing itself was 8.5 OZ & fat on top of it. CG check showed it was really tail heavy, balancing about 1 3/4" in from the t.e. . I tried to fly it this way but it stalled like crazy. I had to add 2 3/4 OZ lead shot to the nose to get it to balance per the plans which glide tests showed was correct. This put the RTF weight of the plane close to 20 ounces!
I was not happy with the glide tests. Glide ratio was awful and the plane shows poor yaw & roll stability. This plane is so heavy that about the highest you can discus launch it is about 50 feet. It seems to want to go inverted on the launch as a video on this thread shows. I had a moderately rough landing and the main wing joiner tube broke away from its glue joints inside the wing.
And so it sits on my bench. After lengthy consideration I have decided to write it off as a loss rather than repair it. I have no slopes to fly it at, and no desire to put a tow hook in it to hi start it. In order for this plane to fly OK it would have to lose 6 or 7 ounces, and there is no way I can do that. I am a builder and my few experiences with ARF's have soured my opinion of them
20 ounces = 567 gram...
Nou da's dus langzaam wel duidelijk.
Apollo van Hobbyking DLG, Not dus.
Best jammer.
Voor mensen die eens willen proeven aan DLG en niet gelijk een "vermogen" willen uitgeven is er niet veel keuze.
Tuurlijk zijn er wel tweedehands modellen maar daar heeft niet iedereen toegang toe.
In de goedkope reeks met modellen zijn helaas dus modellen te koop de het predicaat DLG niet verdienen, Fling en nu ook de Apollo van Hobbyking.
Wat er al beter uitziet is de MARABU.
Model €130
Model met servo's €197
Arf Model met servo's €266
Marabu dlg... Possibly new ?? - RC Groups
thmb_resize.php
RC TEAM Karel Svoboda
HD 44ds servo
Frans
Twee keer D47 + twee keer D60, ontvangertje, wat single cell lipo's.. Kun je voor iets meer dan 300 euro een vliegklare DLG hebben. Geen gekke instap prijs inderdaad :)
Ik heb ze sinds vrijdag beide (Marabu en YoYo) toegekregen. De verzendkosten waren gelijk voor 1 of voor 2 toestellen en dus ze allebei gekocht.
De dozen zijn beide geopend, maar omdat ik het druk had is het bij een visuele inspectie gebleven.
Als je meer info wil of fotos, laat maar horen.
iemand ooit zo'n kist van hobbyarena gekocht ?
Die yoyo of marabu ...
Zien er idd heel erg leuk uit.
Mag ik vragen wat je uiteindelijk voor beide kistjes samen hebt betaald?
Naar de prijs ben ik ook benieuwd. Eigenlijk zou je er een apart draadje van moeten maken. Dit zou over de apollo moeten gaan (ik beken ook schuld trouwens)
fotos/filmpjes/ervaring... Alles is meegenomen.
En hoe vliegen die toestelletjes?
Wil er nl zelf ook mee starten.
