Travel Air 2000?
Mis alleen die verrekte oliekoeler
[FONT=Verdana, Arial][SIZE=-1]In January 1932 John Northrop and Donald Douglas formed the Northrop Corporation as a partly-owned subsidiary of the Douglas Aircraft Co. The first aircraft from the new corporation was the Northrop Gamma, several of which were built to special order for record-breaking flights and research work. The first two aircraft, a Gamma 2A and a Gamma 2B, were powered respectively by a 585kW Wright and 373kW Pratt & Whitney Wasp radial; both were delivered at the end of 1932, the first to Texaco who loaned it to Frank Hawks for record-breaking flights and the second to Lincoln Ellsworth, who eventually used it for a transantarctic flight. TWA bought three Gamma 2D aircraft with 529kW Wright Cyclone engines as single-seat mailplanes in 1934. The second was later reengined with a 578kW Wright and was used by Texaco to test oil temperatures and flows before being sold to the US Army Air Corps, which designated it UC-100. [/SIZE][/FONT]
[FONT=Verdana, Arial][SIZE=-1]A number of Gammas were delivered to individual customers, including two to the UK, a 2E for the Aeroplane & Armament Experimental Establishment and a Gamma 2L, the last to be built, was used by the Bristol Aeroplane Co. as a test-bed for its Hercules engines. The Chinese government ordered 24 Gamma 2E aircraft as light bombers, with 529kW Wright engines; they could carry a 726kg bombload and had four 7.62mm forward-firing machine-guns in the wings, and one rearward-firing in the rear cockpit. A further 25 Gamma 2Es were assembled in China from components provided by Northrop. [/SIZE][/FONT]
het achterste landingsgestel ziet er redelijk fragiel uit....
The Yak-1000 was a high-speed research aircraft. It was the smallest aircraft that could be buit around the powerful AL-5 engine, with a tubular fuselage, a circular nose intake, short-span cropped-delta wings, and bicycle landing gear. The outcome of high-speed taxying trials was such that it was not attempted to fly the Yak-1000.
