Gyroplane - Helicopter Comparison
The Gyroplane
* Thrust is produced by an engine-driven propeller
* The unpowered, freely turning rotor is tilted back as the gyroplane moves forward
* Oncoming airflow through the rotor causes it to spin, producing lift. This is called autorotation.
* Always operates in autorotation, thus:
* Cannot stall like fixed wing aircraft
* Flies safely at low altitudes and low speeds, but cannot hover
* No need for heavy main rotor transmission nor a tail rotor
The Helicopter
* The powered rotor produces both lift and thrust, and is tilted forward
* Can hover, but a powered rotor requires:
* Adequate forward speed and/or altitude to maintain flight in case of power failure
* A heavy main transmission
* Tail rotor to counteract the torque imposed on the aircraft
A Gyroplane can fly more slowly than airplanes and will not stall. They can fly faster than helicopters but cannot hover. Since the rotor blades on the gyroplane are powered only by the air (autorotation), much like a windmill, there is no need for a tail rotor for anti-torque. The gyroplane is a stable flying platform. This is not so with helicopters, which pull the air down through engine-powered rotor blades making it possible to hover, but also making the aircraft very complicated and expensive to fly. Due to their inherent simplicity, gyroplanes are easier to operate and less expensive to maintain than helicopters.
The simplicity of a gyroplane's design translates directly into safety, higher performance, higher mission readiness, lower maintenance, and more economical operation for its operator.
Gyroplanes in flight are always in autorotation. If power fails in a gyroplane the autorotation continues, and the aircraft settles softly to the ground from any altitude. The procedure to land after a power failure is nearly the same procedure as a normal landing, which requires no landing roll. Thus the gyroplane is a safer aircraft for low and slow flight, as compared with both helicopters and airplanes. The ability of gyroplanes to fly faster than helicopters and slower than airplanes makes it something of a hybrid, having the good qualities of the other two types of aircraft with little of the bad.
The single attraction of helicopters over gyroplanes is their ability to hover, which is necessary in some situations such as rescue or in sling load work. In air surveillance and point-to-point flying, not being able to hover is not a disadvantage because many gyroplanes take off and land vertically without having to hover. Helicopters at low altitude out of ground effect avoid hovering whenever possible. It is too dangerous. To fix surveillance on one spot, proper procedure for all rotorcraft is to circle in a slow orbit.
