Instellen Lipo stand Losi Mini 8IGHT
Discussie in 'Model elektronica' gestart door renem, 13 mrt 2015.
  1. renem
    renem
    26 apr 2009
    Oldeberkoop (Friesland)
    Ik probeer de regelaar die bij deze auto zit in de Lipo stand te zetten echter zonder succes.
    Weet iemand hoe je dit kunt doen? (handleiding is niet duidelijk)
    Regelaar is een Dynamite DYN4840WP
  2. cdrom flyer
    cdrom flyer
    19 mrt 2006
    Uithoorn
    Ik heb dit voor je kunnen vinden.
    Ik hoop dat je er iets verder mee komt maar daar zal je het mee moeten doen.;)
    http://www.dynamiterc.com/ProdInfo/Files/DYN4840WP_Manual.pdf
    Transmitter Controlled Programming
    1. Power ON the transmitter and set the transmitter’s throttle endpoint travel to maximum and the throttle trim
    to the center position.
    2. Hold the throttle trigger at full throttle, then power ON the ESC.
    3. Continue holding the throttle trigger at full throttle until a beep sounds and both red and green LEDs flash,
    then release the throttle to neutral.
    4. The ESC is now in programming mode.The ESC will cycle through its programmable featuresin this order:
    A. Green LED only: Change Battery Chemistry Type: Ni-MH or Li-Po
    B. Red LED only: Transmitter/ESC Endpoint Calibration
    C. Red + Green LED: Change ESC Running Mode: Forward/Reverse (Smart Brake) or Forward Only (Brake)
    5. Move the throttle trigger to full throttle and back to neutral at A, B or C in order to execute the setting task:
    A. Change Battery Chemistry Type: Ni-MH or Li-Po
    • The respective LED will indicate the current batterytype for 4 seconds:
    Solid Green LED: Ni-MH
    Solid Red LED: Li-Po
    • Move the throttle trigger to full throttle and return to neutral within the 4 seconds.A beep willsound and
    the respective LED will indicate the updated battery type.
    • To change back to the previous batterytype, repeat the step above within 4 seconds of the beep.
    • Both red and green LEDs will flash 3 times with 3 beeps.
    • Power OFF the ESC and then power ON the ESC to return to normal operation.
    B. Transmitter/ESC Endpoint Calibration
    • After executing the setting task, the green LED will flash asyou release the throttle trigger to neutral. Once
    neutral is reached, a beep will sound and the green LED will glow solid for 1 second. The red LED will
    begin to flash.
    • Move the throttle trigger to full throttle and hold it until a beep sounds and the red LED glowssolid for
    1 second. Release the throttle trigger to neutral and the red LED will glow solid while the green LED will
    begin to flash.
    • Move the throttle trigger to full brake/reverse and hold until a beep sounds and the green LED glowssolid.
    • Release the throttle trigger to neutral. Both red and green LEDs will flash 3 times with 3 beeps.
  3. renem
    renem
    26 apr 2009
    Beste CDROM, de handleiding had ik wel. Deze is nogal onduidelijk. Dat is dus altijd het probleem met weinig knopjes en lampjes.
    Alles heeft dubbel functies met alle gevolgen van dien. In de program mode komen is het probleem niet, maar daarna. Hoe selecteer je als je op optie A zit de keuzes die daar weer achter vallen?
  4. Ernst Grundmann
    27 aug 2002
    Woerden
    Toch staat er in die handleiding alles wat je nodig hebt. Toegegeven het is niet een één twee drie kwestie, je moet alles een paar keer goed doorlezen. Daarna stap voor stap, strikt volgens de opgegeven volgorde werken. Je kan niet ergens een stap overslaan!
    Maar kijk ook eens of er voor deze regelaar een programmeerkaart beschikbaar is. Daarmee kan je die instellingen veel makkelijker doen.
  5. cdrom flyer
    cdrom flyer
    19 mrt 2006
    Uithoorn
    Ja ik weet wat het probleem is.
    Je zit te programmeren en weet even de volgende stap niet maar daar trekt zo een regelaar zicht niets van aan die gaat gewoon door.
    Gewoon overnieuw beginnen is het devies net zo lang tot je de stappen uit je hoofd weet en je het snel genoeg kan om de beepjes bij te houden.
    Het is net een liedje uit je hoofd leren.:)
    Een programmeerkaart is i.d.d. ook een oplossing.;)
  6. renem
    renem
    26 apr 2009
    Helaas kom ik niet verder......natuurlijk kom ik in de program mode waar 3 modi voorbij komen A (green led), B (red led) en C (red + green led).
    Maar hoe bevestig je nu een van die modi A, B of C Ik moet dus in modus A zien te raken waarin in dan de accu soort kan instellen.
    Schematisch moet ik hier naartoe:
    Program>> A >>Solid Red LED: Li-Po
    Ja ik ben erg dom idd.......schijnbaar.....zucht.....
  7. Ernst Grundmann
    27 aug 2002
    Woerden
    Dat staat in stap 4!
    "The ESC will cycle through its programmable features in this order:"
    Eenmaal in de programmeer mode stapt hij zelf door de modes heen.
    Om de instelling te veranderen moet je het volgende doen:
    "Move the throttle trigger to full throttle and return to neutral within the 4 seconds. A beep will sound and the respective LED will indicate the updated battery type."
    Natuurlijk ben je heel dom, dat zijn alle modelbouwers, dom dat ze met deze hobby zijn begonnen. :):):)
    Nee dat is grote onzin. Het is lastig om op deze manier de regelaar te programmeren, maar het is te doen! Het is net een soort mantra. ;) Je moet de hele reeks in je hoofd prenten zodat je min of meer automatisch elke stap langs kan gaan. Eenmaal ingesteld zal je het niet meer hoeven te doen en kan je het allemaal weer "vergeten".
  8. renem
    renem
    26 apr 2009
    Voor de goede orde de regelaar zou moeten opstarten met een rode led ipv een groene led om aan te geven dat hij in de LiPo stand staat bij normale inschakeling?
  9. renem
    renem
    26 apr 2009
    Program card vond dit: Fuze Quick Programming Card | HorizonHobby.
    Zou je daar ook tot nu toe onbereikbare functies mee kunnen benaderen? En werkt deze kaart ook op de ESC? (zal wel toch is een Fuze motor icm dynamite ESC)
