Hallo allemaal, Ik ben aan het twijfelen tussen deze 2 auto's. welke van de 2 is de beste ervan? onderdelen moeten goed beschikbaar zijn. prijs ervan maakt niet uit bij de onderdelen. Specs DBX VE: Kyosho announces the new DBX VE brushless powered racing buggy. The DBX VE brings you the best of both worlds, Kyoshos legendary world championship quality and Team Orions superior performing Vortex brushless system. This isn`t just a nitro buggy chassis with a motor. This is a brand new buggy platform from the ground up, strategically placed components achieve optimal weight balance and handling characteristics. The deep stroke 4-wheel independent suspension and full-time 4WD drive-train powered by the Team Orion Experience B/L means nothing can stand in your way. Fully-factory assembled and in a Readyset package for instant off-road excitement. Features: Fully assembled Readyset package Pre-painted low-profile aerodynamic buggy body Perfex KT-6 steerwheel RC system Team Orion Experience brushless motor 540 size 3720 KV Sensorless Built in Cooling Fins Team Orion Experience sensorless ESC Accepts 6-7 cell NiMh or 2-3S Lipo Forward/ Brake/ Reverse or Forward only Continuous Max Current 70A Peak Current 150A Deans power plugs Digital steering servo Anodised black aluminum motor mount Shaft driven 4WD transmission Machine steel pinion gear Long span double wishbone, 4-wheel independent suspension New steering layout giving greater response Big-Bore large capacity oil shocks Aggressive pin-spike tyres with inner sponges on wide racing wheels 12mm hex drive Width: 326mm Length: 450mm Height: 150mm Wheelbase (min): 299mm *Requires, 6 or 7 cell NiMh or 2S-3S LiPo battery pack, suitable charger and 8x AA batteries for transmitter Specs van de Rustler VXL: Extreme Brushless Horsepower! NEW TQ 2.4GHz Transmitter and Receiver Waterproof Electronics for All-Weather Driving Excitement Top Speed: 70+mph! The Rustler VXL combines Velineon extreme brushless horsepower with the proven fun and durability that have made Rustler the number-1 selling electric stadium racer. The new Velineon Brushless Power System launches Rustler VXL to new heights with speed potential that reaches beyond 70mph! Hardcore, wheel-standing acceleration completely blows everything else away. Out of the box, Velineon is optimized to actually deliver the tire-melting horsepower, benchmark speed, and precision throttle response you expect from brushless. Best of all, it’s brushless done the Traxxas way: wicked fast and easy to use. There`s no tricky programming to figure out or a glossary of new vocabulary to learn. Just plug it in and it works. The Velineon Brushless Power system takes the guesswork out of enjoying the benefits of world-class brushless power. The system components work together as an optimized package, engineered from the start to deliver the ultimate in efficiency, speed, and run time. With the Rustler VXL, Your battery selection determines your speed and skill level. Velineon accepts the widest range of battery types, including 3-cell Lithium Polymer packs (3S LiPo packs). These packs pump out over 11 volts of power for intense, skill level 5 speeds beyond 70mph! Nothing else even comes close. Built-in low-voltage detection in the VXL-3s Electronic Speed Control conveniently helps you maintain your LiPo battery packs in top condition. * Requires Optional Pinion Gear (sold separately). The Rustler VXL now includes the Traxxas TQ 2.4GHz steerwheel radio system. This new system offers the unbeatable convenience of no channels, no crystals 2.4Ghz technology, but that is just the beginning. The new TQ 2.4GHz radio is also features a built-in programmable failsafe, worry free long range control, 50/50 or 70/30 trigger neutral adjustment and the comfortable TQ case design. Sealed Electronics Extend Your Driving Fun Traxxas shocked enthusiasts with the release of our exclusive watertight, sealed electronics in the E-Maxx that provided the freedom to drive where you want to drive through water, mud, snow, and other wet-running conditions that wouldn’t have been possible before. Now the Traxxas Rustler VXL is Ready-To-Race with this waterproof technology. The VXL-3s speed control, high torque servo, and mini receiver are sealed against the elements giving you the freedom go places you might not have thought possible. It opens up a whole new world of adventure and fun. Wet muddy tracks are no problem for the Rustler VXL. The Velineon 3500 Brushless Motor is precision-matched for use in the 1/10th scale Rustler, delivering the perfect balance of brutal horsepower and efficiency. The sensorless design works with the sophisticated circuitry in the VXL-3s Electronic Speed Control for smooth starts and precise control, without the need for additional sensors and wiring. Since there are no brushes or commutator to cause friction and wear, Velineon brushless power is always fast, run after run. The Velineon VXL-3s forward/reverse electronic speed control simplifies brushless technology with easy operation that gives you all the control you need for maximum fun. Quickly choose from 3 drive profiles in exactly the same manner as other Traxxas electronic speed controls (such as the XL-5). Profiles include: Sport, Race, and Training Mode (patent pending). Training Mode limits full-throttle power to 50% allowing young or new drivers to safely develop their control skills before unleashing the full-throttle capability of the Velineon system. Rustler VXL’s performance can be tailored for drivers of any age and experience. High-frequency transistors and advanced circuit design deliver incredibly smooth and refined throttle control. With the VXL-3s you have the flexibility to use conventional brushed motors, brushless motors, and sensored brushless motors. The VXL-3s auto detects the motor type for you. High-current capacity (320 amps peak) and two-stage thermal protection frees you from motor limits. The Rustler VXL is equipped to handle serious horsepower with features such as the advanced Revo-spec Torque-Control slipper clutch. The patent-pending design delivers smooth operation, precise adjustment, and consistent traction control, even when tortured with massive amounts of horsepower. New upgrades to the Rustler VXL include high-grade hex hardware, precision metal turnbuckle links with heavy-duty rod ends, and larger 5x11mm rubber-sealed ball bearings at the wheels. The transmission is beefed-up as well with tough new steel gears. With so much speed available, the Rustler VXL is equipped with an all-new digital high-torque steering waterproof servo for lightning-quick steering response and confidence-inspiring precision. QUICK FEATURES ON RUSTLER VXL New TQ 2.4GHz Transmitter and Receiver Waterproof Electronics Traxxas High-Current Connector Maxx Cable 12-gauge wiring Digital high-torque steering waterproof servo Precision steel turnbuckles with heavy-duty rod ends Metric hex hardware Front suspension tie bar Steel transmission gears 5x11 rubber sealed ball bearings at the wheels Traxxas backs the Rustler VXL and all of their products with top-notch support that is second to none. A staff of skilled representatives is on-hand to answer your questions via phone, website, or email. Unmatched parts support allows Rustler VXL to be serviced with parts and support from thousands of hobby dealers worldwide. Your investment is also protected by the Traxxas Lifetime Electronics Warranty. Traxxas goes the extra mile to ensure that your R/C experience is easy and fun (and fast!). Follow the details link above to go in depth on all the Rustler VXL performance benefits and also be sure to check out the videos page to see Rustler VXL in action for yourself. MODEL 3707: Fully assembled, Ready-To-Race, TQ 2.4GHz High Output radio system, Velineon Brushless Power System, and ProGraphix painted body. dat 2,4ghz moet je even negeren want als ik de rustler vxl neem word het de 27mhz. dus kunnen jullie me helpen? mvg, Paul Benard:rolling:
