M
m_theloosen2
Lipo lader Smart plus 12V 2-5 cellen met balancer Euro 61,00
Smart Plus LPC-1080" 2-5cells Li-poly Balance High Performance Charger
1) Batteries: Li-ion, Li-poly 7.4v - 18.5v - DC 12V input clips
2) Size: 140mm*80mm*31mm - Aluminum alloy shell
3) Input voltage: 12v-15v - Charging condition LED
4) Charger current: 1.3A steady current(4.2v steady voltage) - Cool fan
5) Power Consumption: Less than 5W of 12V (at idle) - Charging port from 2-5cells
6) Device weight: 400g (0.88 lbs) - Secondary charge port for 2 Li-Po battery packs charged same time
7) Automatic balance charge and test cell function - Instruction manual in English
Wil deze misschien gaan kopen om deze : Lipo accu 11,1V 1200 mAh 10C op te laden. Maar kan dat wel omdat er boven aan staat 2-5cells Li-poly Balance High Performance Charger. De accu is 10 Cells en mij moet op 1c kunnen laden.
