mini quadcopter
vinnygogo
Forum veteraan
hallo allemaal,
na veel gelezen te hebben en door jullie lekker gemaakt te zijn, heb ik vanmiddag besloten een mini quadcopter te gaan bouwen. motor tot motor zal tussen de 20-30 cm zijn, ga het frame zelf maken. hieronder de onderdelen die ik besteld heb bij hobbyking:
1x #QUAD-CON16K/19534 HobbyKing Quadcopter Control Board V2.1 (Atmega168PA) = $19.95
1x #9171000003/21321 USBasp AVR Programming Device for ATMEL proccessors = $4.95
5x #1811-2000/5358 18-11 2000kv Micro Brushless Outrunner (10g) = $39.95
5x #HK-SS10A/6455 Hobbyking SS Series 8-10A ESC = $32.50
1x #HCB-05/11328 5x3 Propellers (Standard and Counter Rotating) (6pc) = $2.53
4x #GS0152M/8721 Prop adapter w/ Alu Cone M5x2mm shaft (Grub Screw Type) = $7.96
1x #R14A707-06/9678 Turnigy Pure-Silicone Wire 1 4AWG (1mtr) RED = $1.39
1x #B14A707-06/9679 Turnigy Pure-Silicone Wire 14AWG (1mtr) BLACK = $1.39
2x #B20A195-06/9654 Turnigy Pure-Silicone Wire 20AWG (1mtr) Black = $1.58
1x #606A-606B/11961 Nylon T-Connectors 10 Pairs (20pc) = $3.08
1x #AM-9017A/9683 Female JST battery pigtail 12cm length (10pcs/bag) = $1.59
1x #AM-9017B/9682 Male JST battery pigtail 10cm length (10pcs/bag) = $1.48
2x #AM1001A/68 PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) = $3.18
2x #Turnigy-HKLP/11736 Turnigy Battery Strap 330mm = $3.18
1x #AM1043-40-32/9708 40CM Servo Lead (JR) 32AWG Ultra Light (10pcs/bag) = $2.39
1x #WHS-4MM-RED/5277 Turnigy 4mm Heat Shrink Tube - RED (1mtr) = $0.35
1x #WH-4MM-BLACK/3832 Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) = $0.35
1x #WH-2MM-BLACK/5205 Turnigy 2mm Heat Shrink Tube - BLACK (1mtr) = $0.25
1x #WHS-2MM-RED/5276 Turnigy 2mm Heat Shrink Tube - RED (1mtr) = $0.35
1x #XD-KP-237/9333 X-BLADE Spare SK-5 Steel bl ades (10pcs/set) = $0.99
1x #XD-119-4B/9332 X-BLADE Precision knife with replaceable SK-5 blade = $0.49
1x #Magnet-R/7645 Strong Rare-Earth Button Magnets (10pcs/set) = $2.48
1x #TGS5x5E/7934 TGS Sport 5x5E Precision propeller = $0.43
1x #HLFT-01/9374 Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr) = $2.39
1x #D6FR/16675 FrSKY D6FR ACCST 6 Channel RX = $19.99
hoop de spullen snel binnen te hebben zodat ik met de bouw kan beginnen. alle tips zijn welkom!
Je zal kleiner moeten gaan met het frame en het heel licht houden met die kleine motoren. Eerder 15 cm motor naar motor.
ok bedankt voor de tip! ga het allemaal even uitleggen als ik het binnen heb,dan kan ik de precieze maat kiezen. maar ga er rekening mee houden;)
Waarom geen houten frame van HK genomen ?
Lichter kan je dat nooit zelf maken , alu buis word al te zwaar .
De nieuwe HK frame,s zijn stabiel genoeg als je die met bruislijm lijmt .
Ik maak ze ook met de 10 gr. motortjes .
Mvg Johan
De grote speelt geen rol , het is het gewicht wat een rol gaat spelen.
Ook al word hij 1 meter , als je maar onder de 400 gram blijft .
Dat nieuwe frame (kleine versie) weegt kompleet 100 gram als die verlijmt is met Pu-lijm . (oude versie is veel zwaarder)
Je krijgt een zelf gemaakt frame nooit zo licht zonder CNC frees.
Mvg Johan
Een meter quad is nou niet echt meer mini hè ? ;)
Zoveel gewicht voeg je niet toe met een paar 6x6 / 8x8mm grenen/vuren latjes.
Je bouwt zo'n ding voor waar hij voor bedoeld is dus met een beetje logisch nadenken komt het vanzelf goed.
Je maakt een indoortje ook niet van betontriplex.
Bedrading kort houden en slim met de motor bevestigingen omgaan valt veel meer uit te halen dan framepje A of B. Zeker met zelfbouw zonder al te veel poespas is zeker lichter dan een compleet triplex frame.
Denk dat een framepje voor iets als dit niet veel meer dan 50 gram mag wegen.
Bedrading kort houden en slim met de motor bevestigingen omgaan valt veel meer uit te halen dan frampje A of B. Zeker met zelfbouw zonder al te veel poespas is zeker lichter dan een compleet triplex frame.
of te wel 218,6 mm van motor tot motor.
gegroet ;)
Het was ook alleen als vergelijk bedoeld , voor de motoren speelt grote geen rol , alleen gewicht of weerstand .
Met die 10 grams motoren telt elke gram
Deze weegt 416 gram met een 2S1300
full
Getest met een 2S4000 , dan is het 536 gram en dat is teveel om normaal te kunnen vliegen .
Mvg Johan
Maar waarom zou je dan voor zulke kleine motoren gaan om ze vervolgens op een lomp frame te zetten.
2 januari alles verstuurd, vandaag bezorgd! en dat met standaard airmail:D. net bij de bouwmarkt een vierkant grenen lat gehaalt en hier het frame uit gemaakt. frame is nu 30 cm motor tot motor. heb dit gedaan omdat ik dat een mooi maatje vond. ga kijken hoe het vliegt, kan altijd de motoren nog iets naar binnen zetten en iets van de uiteinden afzagen. ga nu verder met alles monteren en solderen en hoop het weekend de maiden!!
EDIT: kom er nu net achter dat er bij het bordje geen male-male servo stekkertjes zitten. dacht dat deze er bij zaten, maar nu kan ik ontvanger dus niet aansluiten. heb ze meteen besteld bij hobbyking, maar die zijn er natuurlijk niet het weekend:( toevallig iemand in omgeving bilthoven/utrecht die 4 van die kabeltjes heeft liggen die ik morgen zou kunnen ophalen en overnemen/lenen??
male male kan je toch wel even zelf solderen? Standaard inderdaad + configuratie, even delta mix aanzetten in je zender en je vliegt in x mode.
Nee blijft in + stand. Het boardje stabiliseert alleen je quadcopter voor de rest niet. Daar verandert niets aan als je in x gaat vliegen. Het enige verschil tussen x en + is de controle die jij hebt. Je verspreidt je controls over 2 assen. Meer niet.
@hugo,
ja ik kan zeker wel solderen, heb alleen waarschijnlijk niet genoeg servo kabeltjes om ze te solderen. heb dan namelijk 8 servo verlengkabeltjes nodig;) zal morgen nog ff goed zoeken, maar mocht iemand in de buurt nog hebben liggen hoor ik het graag!!
van + naar x configuratie gaan we binnekort ook maar eens proberen, maar eerst maar is in + vliegend krijgen;)
heb een paar servo verlengkabels gevonden, maar nog geen acht:( nu zat ik even te denken. ik hoef niet van alle kanalen plus min en puls te doen toch? als ik van alle kanalen de puls doe en van 1 kanaal ook de plus en min werkt het ook toch?
