rc monster zei:
loud wat heb jij dan allemaal al verbouwt aan je savage ??
koop direct bij de set een luchtfilter van GPM die grote blauwe
is dat beetje goede filter
Pff dat wordt dan een lang lijstje
Er zit nu in:
Proline Jeep CJ8 T/E-Maxx Body
HPI Roto Start System Savage
HPI 1200 mAh Hump 6v Receiver Pack
RPM Monster Clawz 6-Spoke StableMaxx Chrome T/E-Maxx (2)
Proline Maxx Mulcher Front/Rear Truck Tire T/E-Maxx(2)
Trinity T-Maxx Foam Insert (4)
HPI Aluminum Mount & Retainer Set Savage SS
HPI Savage Air Filter
HPI Adjustable Upper Arm Set Savage
HPI Fuel Tank 160cc Savage 25 RTR
HPI Heavy Duty Cup Joint 6x13x20mm Silver (2)
HPI Bevel Gear Set (Gear Differential) (2)
Hot Bodies Clamp-On Aluminum Hex Wheel Hub Savage
Hot Bodies Threaded Shocks
Hot Bodies Drive Shaft Pair (2)
Hot Bodies Rear Center Drive Shaft
Hot Bodies Front Center Drive Shaft
Hot Bodies Heavy Duty Steel Disk Brake Hub Savage
Ofna Hardened Clutch Bell 16T
Ofna Steering Linkage Kit Yellow
Ofna Servo Saver w/Bearings 6x10mm
Ofna Servo Linkage Kit Yellow
Ofna Linkage Sliders Kit Yellow
Ofna Aluminum Fuel Filter & Primer Pump
Ofna Fuel Line Clips
Ofna 3000 Weight Silicone Diff Oil
Ofna 7000 Weight Silicone Diff Oil
Mugen Carbon Shoe 3-Pin MBX-4
Mugen Clutch Spring 3-Pin MBX-4
Du-Bro Alloy Fuel Filter - Silver
Du-bro 2168 Socket Set Screws 3x3mm
Trinity 45 Weight Silicone Shock Oil (2)
Team Associated Green Slime
Traxxas Rubber Pipe Exhaust Rustler
Delrin 51T Spur Gear
Hitec Standard Metal Horn 3/4" Single Sided
Hitec HS-645 MG Ultra torque 9.6 kg.cm
THS Racing Pipe Set Savage 1/8
GPM Alloy Fuel Tank Protector - Silver
Ernst Charge Receptacle Futaba FM
Hobbico Switch Harness w/Charge Plug Futaba J
General Silicones Fuel Line Medium 2' Solid Flourescent Yellow
ENVY Vented 3 Shoe Flywheel/Clutch Kit 30mm - Silver
KYOSHO Bevel Gear Shaft Set
Envy Aramid Pad Dual Disk Brake Kit
WFC 117mm Shiny Purple 6lb. Springs
Unknown Black Shock Socks
Komt deze maand nog binnen:
HoleShotEngineering HPI SAVAGE FEATHERWEIGHT CHASSIS PLATE SET
VENOM Failsave
PICCO P3 Monster .26
Graupner XS6 Race
Er zat in:
Ofna Fuel Tank 125cc
Hayes Regular Fuel Tank 2 oz.
HPI Heavy Duty Dog Bone 9x123mm Savage (4)
Ik heb dus deze mods gedaan:
Dual tank mod - zit er niet meer in
Servosaver mod
Steering linkage mod
gas/brake linkage mod
spider gear mod
dual disc brake mod
humppack battery
3 shoe clutch mod
reverse driving mod
ehm dat was het geloof ik
