Servo's in de Trex 600 CB
Dat klopt,..
je kunt ze id zonder rubbers monteren.
ik heb mij laten vertellen dat dat kan omdat er veel minder trillingen zijn dan bij brandstof heli's
Heb eigenlijk nog een vraag.
In de heli heb ik 3x een S9252 servo zitten, overal lees ik dat deze alleen maar goed is voor 4.8 Volt.
Maar bij de Trex600 zit de BEC3x en deze heeft 5,8 Volt op de uitgang.
Kan ik nu zonder problemen toch de S9252 servo's gebruiken?
Ik neem aan dat voor de R149DP ontvanger en de 401 gyro het geen probleem is?
van de Futaba site gekopieerd:
SPECS: Speed: .14 sec/60° (based on 4.8V rating)
Torque: 92 oz-in (6.6 kg-cm) (based on 4.8V rating)
Weight: 1.8oz (50g)
Power Supply: 4.8V (Futaba does not recommend using 6V)
Length: 1.6" (41mm)
Width: .8" (20mm)
_ Height: 1.5" (38mm)
COMMENTS: S9252 Digital Servo Precautions,
-It is best to avoid long leads and Y-harnesses especially with
standard grade wires. If problems are encountered, consider using
heavy duty wire such as Futaba's Heavy Duty Series or Hobbico's
Pro Series ,minimizing lead lengths, and/or removing Y-harnesses.
-Current Drain: Futaba S9252 Servo is specially designed for high-
torque and high-speed, therefore very high current drain is
normal at startup. For ultimate performance when using this servo,
please review the following points.
(1) Always use a 4.8V NiCd battery. Dry cells are rated at 1.5V
each making the overall voltage 6.0V which will damage the gyro.
(2) When using systems with the battery fail safe function it has
a higher cut-off voltage setting which will cause shorter
operation time.
(3) When installing the servo please check pushrod linkage to make
sure there is no binding in order to prevent excessive power
consumption and decrease the life of the motor and battery.
When Used With GY501 Gyro:
Switch the GY501 servo frame rate function (Frm) from "NOR" to
"High" to display the performance of the gyro to the fullest.
Setting Method:
(1) Press the GY501 FUNC+ or - key to call the Servo Frame Rate
Setup Screen.
(2) Press the DATA+ or - key to display "High".
This digital servo cannot be used with the following * AM *
transmitters as the servo neutral signal is: 1310us).
CONQUEST AM, FG Series (T4FG, T5FGK,T6FG, T6FGK, T7FGK), New Terratop,
T3EGX, T3PGE, T2NL, T2LGX, T2FR, T2PK series.
**** Otherwise they will work fine with current AM systems *****
Aad.
9252's hebben geen problemen met 5,8v, de staartservo echter wel maar daar is de "step down" (diode) voor bijgeleverd. Deze zorgt ervoor dat de staartservo maar 5,1v krijgt. De gyro werkt ook prima op 5,8v.
Cheers,
Richard
Het is toch erg verwarrend wat Robbe zegt, maar ik vertrouw maar op Raptor Rulezzz hij heeft toch wel veel ervaring.
En volgens mij heeft iedereen in zijn Trex zo ongeveer die S9252's zitten, dus zal wel gaan zonder problemen.
Mocht je een keer in de buurt gaan vliegen, kom ik graag een keer langs en neem dan ook even mijn Trex mee
zodat je er misschien even naar kan kijken of het allemaal goed zit. Ik heb een FF9 zender die ik uiteraard ook mee zal nemen.
Wacht alleen nog wel op mijn LiPo lader en vliegaccu. dus kan nog niet vliegen.
Uiteraard andere Trex600 vliegers in de buurt zijn ook meer dan welkom.
Mag natuurlijk ook ergens in de buurt van Raptor Rulezzz zijn, ik kom wel als het een beetje binnen de 40 KM blijft.
Zo te zien lopen jou stuur stangen niet parallel met het frame.
Is er dan een "bijzondere" rede hiervoor?....behalve dan dat het niet uitkomt met jou concept?
Ik persoonlijk hou ervan om alles parallel en haaks mogelijk te houden.
(lees: efficientie en "stress" van de servo.....of is dit te verwaarlozen???)
Ik gebruik ook de 9252's op mijn 600 die wel parallel staan :wink:
Groets
Moos
Zo te zien lopen de linkes beide onder een zelfde hoek, stress zal er dus niet optreden. Wel meer cyclic uitslag.
Ik bedoel meer als, stress per servo, dan het totale.
Denk aan de axiale krachten per servo....die duwt dan niet meer voor zich uit, maar boven of onder zich.
Eventueel meer cyclic is al meer dan voldoende als deze parallel staan....(denk ook niet dat dit invloed heeft als die niet parallel staan)
Hoi,
Ik heb bij mijn 9252's er zo'n TT alu servoplaatje bij onder de servo gelegd .
Bollinkjes aan de onderzijde van de servohevel plaatsen , alles staat dan netjes recht en haaks .
suc6
Hoi,
suc6
:wink:
groets,
TEST
Servo met tekst
http://www.kristal-video.nl/Heli-fotos.htm/Servo met tekst.jpg
http://img170.imageshack.us/img170/7123/frameclosejpgjq2.jpg
