van de Futaba site gekopieerd:
SPECS: Speed: .14 sec/60° (based on 4.8V rating)
Torque: 92 oz-in (6.6 kg-cm) (based on 4.8V rating)
Weight: 1.8oz (50g)
Power Supply: 4.8V (Futaba does not recommend using 6V)
Length: 1.6" (41mm)
Width: .8" (20mm)
_ Height: 1.5" (38mm)
COMMENTS: S9252 Digital Servo Precautions,
-It is best to avoid long leads and Y-harnesses especially with
standard grade wires. If problems are encountered, consider using
heavy duty wire such as Futaba's Heavy Duty Series or Hobbico's
Pro Series ,minimizing lead lengths, and/or removing Y-harnesses.
-Current Drain: Futaba S9252 Servo is specially designed for high-
torque and high-speed, therefore very high current drain is
normal at startup. For ultimate performance when using this servo,
please review the following points.
(1) Always use a 4.8V NiCd battery. Dry cells are rated at 1.5V
each making the overall voltage 6.0V which will damage the gyro.
(2) When using systems with the battery fail safe function it has
a higher cut-off voltage setting which will cause shorter
operation time.
(3) When installing the servo please check pushrod linkage to make
sure there is no binding in order to prevent excessive power
consumption and decrease the life of the motor and battery.
When Used With GY501 Gyro:
Switch the GY501 servo frame rate function (Frm) from "NOR" to
"High" to display the performance of the gyro to the fullest.
Setting Method:
(1) Press the GY501 FUNC+ or - key to call the Servo Frame Rate
Setup Screen.
(2) Press the DATA+ or - key to display "High".
This digital servo cannot be used with the following * AM *
transmitters as the servo neutral signal is: 1310us).
CONQUEST AM, FG Series (T4FG, T5FGK,T6FG, T6FGK, T7FGK), New Terratop,
T3EGX, T3PGE, T2NL, T2LGX, T2FR, T2PK series.
**** Otherwise they will work fine with current AM systems *****
Aad.
