Heb het even met een V1 bordje geprobeerd, doet het gewoon. Met de nieuwe V2 ook geen probleem.
Raar dit soort dingen....
Grtz, Frans
dit verhaal gevonden, zoals hier beschreven in post #10
Hi Fellow HeliFreaks,
Forgive me if this information has already been covered before.
I purchased a mCPX v2 at my local Sydney hobby store yesterday, I wanted the BNF which they didn't have, so the shop assistant pulled out the DX4 TX from an RTF pack and sold it to me as a BNF. I took it home and tired to bind to my DX6i, the usual way as I did with the mSR and 120SR. After it bound I noticed it was flashing three pulses at a time. All the cyclic movements worked but no throttle. I spent all night on the forums and wasn't getting anywhere.
I decided to change the Throttle adjust settings from 100% to 95% also changed GYRO (0) from 50% to 65%. I then rebound it and I actually got a solid light and throttle worked!! BUT it it still wasn't working correctly, I noticed after apply full throttle and then bringing it back down again the mCPX throttle cut off and wouldn't spool up again, it was also pulsating 3 flashes again, I had to disconnect and reconnect the battery to get it working again, but again same thing over and over.
I was thinking it had to be a defective 3-in-1 controller. I decided to make a support call to Horizon, the guy was really helpful and he told me that the v2 has only been out for about 2 weeks and that they changed the programming a little.
To bind it to a DX6i or any other computerized TX you need to hold the trainer/bind switch and hold the rudder stick to the RIGHT at the same time and then switch on the TX.. I did exactly that and It worked!! Everything was working correctly with the documented DX6i factory settings.
The guy also mentioned that to bind to then no-computerized TX the rudder stick should be held to the LEFT instead, you see Horizon does have a video describing how to bind, but only to a non-computerized TX. Anyway I hope this helps and I wish you all a Happy New Year.
