The New Quanum 450 Class retract System is a great way to get the landing skids out of view of your camera as well as add some flare and style.
Operating off just a single channel and a universal mounting plate, this is a must have upgrade.
But that’s not all! Some more great features include a quick release lock and rail mount, allowing you to quickly remove the system for easy transportation and storage. There is also a center plate with a standard 45x45mm mounting set below the unit for the gimbal or batteries, so adding this unit does not take away any mounting from the underside of your multirotor. If you have a larger 600 class H frame you could add 2 of these units in line for the ultimate in style and wow factor.
Specs:
Max load: 4Kg
Height: 200mm
Width at Bottom: 215mm
Weight: 151g
Mounting plate: 160x38mm (mounting holes 40 and 25mm x25mm)
Das een gimbal machineZodra projectje helemaal klaar is en goedgekeurd bouw ik er 1 met Naze32 !
