Hier zijn de specs van de kist die ik dit seizoen heb gevlogen (en die was helemaal niet slecht, om het maar eens voorzichtig uit te drukken):
Bluegrass Blitz
Airframe: derivative of ‘Peanuts’ from Henk de Jong => Juno+ with D-tube wing and straight hinge line.
Looks: derivative of KA-8/10 by Anatoli Kolesnikov
T/O weight -61 oz. or 1727 grams
Area (Wing & flaps) - 627 sq.in or 40.5 dm2
Span - 1420 mm (60.6 in)
Wing airfoil - Werwage Juno
Flaps hinge line sweep - none
Hingeline-hingeline - 425 mm or 16.7 in
Empennage airfoil - Built up flat plate 13 mm, elevator tapers to 4 mm @ trailing edge
Fin - Flat plate 5 mm solid balsa
Stabilizer A.o.A. - +/- 0°
Motor thrust angle - +/- 0°
Nose length - 255 mm or 10 in Back plate – leading edge (centre)
Motor axis above wing c.l - 0.86 in or 22 mm
Stabilizer c.l. above wing c.l. - 1.4 in. or 35 mm
Rudder - Neutral, non adjustable
Graphics design - F2Bluegrass - Bruno van Hoek
Power Train
Motor- Torcman NT-350 20Z 14W
http://www.torcman.de/motoren/NT350/nt350zl_e.htm
ESC - Turnigy Thrust 55A
http://www.hobbyking.com/hobbyking/store/__32525__TURNIGY_TRUST_55Al
Mode - Non governor
Timer - Keith Renecle Ver. 2 - governor
http://www.keithrenecle.co.za/Electric CL.htm#Govtimerinfo
BatteryLiPo - Revolectrix 435 Black. Label 30C 4s3100
www.revolectrix.com/Products/3100mAh-4S-Lipo-Blend435-Black-Label-30C-HV
Spark protection - Home made on
- of controller.
Propellor - APC 13 x 6.5 E @ 7800 rpm
http://www.apcprop.com/LP13065E
Spinner -
http://www.hobbyking.com/hobbyking/store/__58227__Turnigy_Turbo_Spinner_57mm_Red.html
_________________
Bench Trim
June 2015
C.G. - 7.3 in or 185 mm from hinge line fwd.
Lead-out Center - 1.8 in or 45 mm. rear of C.G. 6.1 in or 155 mm from hinge line fwd.
Tip weight - Outer tip 1.4 oz or 40 grams heavier
Elevators / Flaps throw - 40° / 40°
Hinge seal - Hollow trailing edge, control surface l. edge half round fits exactly.
Nose trim weight - 0
Tail trim weight - 0
Battery trim position - Fixed, as in : no room to move
Lines - 0.015” x 67.25 ft or 20.5 m (eye-eye), Staystrate: 3 wire tinned
Doe er je voordeel mee.
