Ben er uit , kies voor de Aitis v4
-Altis is kleiner , past beter in iedere kist, heeft een eigen display om direct uit te lezen, en telemetri voor mijn zender Gr Hott enz .
Die andere heeft dure extra optie die je ook gemakkelijk naast Altis kan realiseren of via mijn eigen zender.
1. Strict firmware for FAI F5J where motor restart is not allowed. Exactly as in the rules of FAI F5J
2. Another firmware with open settings. There is an option to allow or deny the restart of the motor.
Ter info:
Altis v4 has the following revolutionary features:
- Integrated OLED display
- No more usb adapter needed
- It has integrated USB micro connector
- It acts as a mass storage device - when plugged to computer it is like a flash drive in the computer - no special driver needed
- 3,5MB memory capacity
Specification:
- Weight 8g
- Dimensions 20x33x6.5mm
- logging altitude, temperature, throttle, voltage
- F5J, ALES and other functionality,
- telemetry ready
- Telemetry support for Jeti model®, Multiplex® M-Link,
Graupner® HOTT
- external sensors ready
Optie (voor de liefhebber)
The Altis V4 Keypad allows the Altis V4 to be setup on the field when loaded with the standard firmware. The keypad allows you to make changes to the motor run time, height cut off, motor restart, competition restart and F5J setting.
Altis v4 | AerobTec
