Oke, dan had je hem nog in de Phantom 2 mode ipv Naza-M mode staan. Dan kun je inderdaad de IOC niet activeren.
Boven aan pagina 25 van het user manual
(1) Users should not enable the Naza-M function before finishing Advanced Flight Maneuvers
procedure in the " PHANTOM Pilot Training Guide”. If the Naza-M mode is enabled, users can
switch the control mode between ATTI. Mode, GPS Mode or Manual Mode, and access the
advanced settings (e.g. IOC). In addition, the LED located on the rear frame arms will display
Naza-M flight status indications instead of the PHANTOM 2's indicators. Do not enable the
Naza-M mode unless you are an experienced user or guided by a professional.
(2) You can change to the Phantom 2 mode by clicking the same button used to turn on the Naza-M
mode. This operation will disable the Naza-M mode and enable Phantom 2 mode. All parameters
will be returned to factory settings.
