CAM Height Limiter
Competition Altimeter for Models
Designed by Soaring Circuits for the US 200m altitude limited electric soaring format, the CAM is small, light, and easy to install. Just plug it in between your receiver and ESC. That's it! The CAM automatically shuts your motor down at 200 meters or after 30 seconds per the emerging altitude limited soaring rules. This simple competition format promises to put the "soaring" back into electric sailplane contests. Even inexpensive RTF models can compete!
The CAM has selectable cutoff altitudes of 100m, 150m and 200m, and does not require a computer to program or use. You can easily change the cutoff right at the field. With the CAM you can make multiple climbs to cutoff without having to land. Great for practicing!
Size: 23 mm x 18 mm x 6.5 mm max
Weight inc leads: 6.5 g (0.23 oz)
Note this device is not legal for UK eSoaring competitions
