Zoals in het onderwerp genoemd, wie heeft ervaring met deze lader?
BMI, Spitz 6R DUAL CHARGER
12V / 240V - 130W
Lipo Recovery System included
Dual input, microprocessor controlled, high efficient digital charger/discharger for NiCd/ NiMH /
Pb / LiPo and LiFe batteries. Especially designed for safe Lipo and LiFe charging and maintenance..
10~15V DC power supply: 130Watt power - 100V~250V AC power supply: 80 Watt power
Easy four button program control
Charging and discharging over the 4mm main connectors
Balancing over the balancer cable HX & EHR
20 data memories
1~20 NiCd/NiMH Delta-peak adjustable (mV)
1~6 LiPo / LiFe cells
2V~24V Pb batteries
Charge current 200mA~10A (AC: Max 80W / DC: 130W)
Discharger current 200mA~2A (Max. 8W)
Timeout limit: The charging stops automatically after a preset period of time
3 different charge modes for LiPo and LiFe batteries: storage(50%), Fast Charge (1/10C) and full charge (100%)
Adjustable discharge Cut-off voltage for Lipo, LiFe, Pb, NiCd and NiMH Batteries
All settings visible on the 2x16 backlight LCD screen while charging
Adjustable end of charge voltage for LiPo and LiFe batteries
LiPo RECOVERY Mode : enables to recover low voltage LiPo and LiFe cells.
Download manual: PDF Spitz 6R Dual charger
alvast bedankt
12V / 240V - 130W
20 data memories
2V~24V Pb batteries
Charge 10A (80W)
Discharge 2A (8W)
Charge & Discharge 9 cycles (Nixx)
Balancer Yes
Input Volt 12V/240V
LiFe PO4 Batt. 1~6 cells
LiPo Batt. 1~6 cells
Memory 20
NiMH & NiCd 1~20 cells
Output Power 80W/130W
Pb Battery 2V-20V
alvast bedankt
