Ik heb net deze besteld... Hopelijk heb ik hem nooit nodig maar het geeft je toch een beetje zekerheid.
Lichtgewicht en lange batterijduur...
FEATURES
Simple to use - simply dial tracking number and it will do the rest.
Safety - Protect your expensive drone, Go-Pros, cameras and mods from missing in action flights and thefts by 3rd parties should your drone land away from you and be recovered by a 3rd party.
Flyable design - lightweight, compact and self contained design that fits on top of your battery in AR drone 2.0 models.
Own power supply – improved reliability & dependency from drone systems without modifications to the drone itself.
Redundancy tracking built in – primary system GPS is accurate to 5m with GPS lock. Secondary system 5-20m when using GPRS signal not locked.
Compatible sim card included– just add credit and have no subscription fees/contracts! (UK only)
Position pinpointed on your mobile phones web browser as a google map with location pin.
SPECIFICATION
Size LxWxD— 7.5cm x 5.0cm x 0.5cm
Weight– 35g
Battery– Rechargeable Li-ion
Battery life– 48 hours constant use per a full charge
Accuracy when GPS signal acquired– <5m
Accuracy when using GPRS signal lock- 5 to 20m
Sim– 2G standard size sim included and tested to be compatible with the Fi-Li-Fi.
Tested with iphones, Blackberrys, Nokia handsets, Android handsets.
FEATURES
SPECIFICATION
Weight– 35g
