westland p12
During 1940 in Britain there were preparations for the defence of the country in the event a German invasion was to take place. Among projected schemes put forward for the strafing of German forces as they hit the beaches and for striking at supporting surface vessels was that of the Westland P-12. The project incorporated a straight modification of the Westland Lysander aircraft. The initial plan was to install two 20mm cannons attached to the fixed undercarriage spats. However a further rethinking led to the redesign of the rear fuselage, this being cut short and a tail turret added, and the adaptation of a new mounted ‘tandem wing’ arrangement complete with endplate fins and rudders for longitudinal stability. When the P-12 first flew on 27th July 1941 it was immediately shown to be highly maneuverable.
toch eens de 175 files bekijken....:!::!::!::!::!::!::!:
dit plaatje is al eens voorgekomen......
ps : al iemand iets gehoord van den dirk....???
ik stel voor dat we wachten tot 24h00.....dan gaan we gewoon weer verder en wordt het intermezzo afgesloten....
als P51d juist is dan kan hij verder gaan en een volgend plaatje lanceren
