FORUMLEDEN met NOSTALGIE......"vreemde" kisten
Status
De 1929 Zenith Z6A
The Z6A cabin biplane was built by the Zenith Aircraft Corporation of Santa Ana, California and is a good example of an early short range airliner. Only one remains airworthy.
NC392V c/n 3 USA
7 seat light aircraft first flown in 1929
Engine: 550hp(410kW) P&W Wasp R-1340 Length: 30’10"(9.39m) Height: 10’10"(3.3m)Wingspan: 41’6"(12.65m) No.built: 5 Range: 650miles(1045km) Cruising speed: 125mph(201kmh) Empty weight: 2300lb(1045kg) Maximum take-off weight: 4394lb(1997kg)
De volgende:
Dit vliegtuig is uitgerust met een 180hp Hispano Suiza eight cylinder Veetype engine.
In February 1918, the Talleres Nacionales de Construcciones Aeronauticas (TNCA), or National Aircraft Manufacturing Workshops, at Balbuena Airfield, Mexico City, completed the prototype of a single-seat fighting scout to the designs of Francisco Santarini and Capt Guillermo Villasana. A single-bay unstaggered biplane known as the Microplano, the aircraft was powered by a 180hp Hispano-Suiza eight-cylinder Vee-type water-cooled engine driving a Mexican Anahuac propeller, and was of metal construction. The intended armament was either one or two synchronised machine guns. Although flight trials of the Microplano were allegedly satisfactory, no series production was undertaken owing to the overthrow of the Carranza regime and the ensuing civil war.
Teus: jij gaat wel van het ene uiterste naar het andere wat betreft 'vindbaarheid' van je opgaven ;)
Bell Model 65 ATV
In 1954, Bell Aircraft Corporation expanded its Vertical Take Off and Landing (VTOL) research program with an examination of
tilt-jets as an alternative to its tilt-rotor system, pioneered on the company's XV-3. Although this privately funded project explored a
new avenue of VTOL technology that ultimately proved unsuccessful, it provided essential data on the challenges inherent to this
type of aircraft.
Lawrence Bell's company survived the post-World War Two slump in the aircraft industry by embracing new technology, including
helicopters and research aircraft such as the record-breaking X-1 (see NASM collection). By the early 1950s, the military had
become interested in VTOL aircraft that combined the vertical flight characteristics of a helicopter with airplane-like speeds. In 1952,
a Bell feasibility study established that VTOL jet fighter designs were possible. The company decided that the potential benefits of
the new technology were worth pursuing, even without the government support that was usually necessary for such projects.
Bell's Niagara Frontier Division managed the construction of an Air Test Vehicle (ATV), designated as the Model 65, to investigate
the use of tilting jet pods to provide lift in vertical flight and forward thrust in horizontal flight. During cruise flight, a conventional
wing provided all of the lift. To complete the aircraft at minimum cost, the design team relied on off-the-shelf components, including
a T-tail Schweizer sailplane fuselage and a Cessna 170 wing. A set of Model 47 helicopter skids supported the ATV on the ground,
which gave the aircraft an ungainly grasshopper-like appearance. The ATV used two Fairchild J44 turbojets, borrowed from the Air
Force, for vertical lift and forward propulsion. These attached to either side of a swivel-mount positioned behind the open cockpit.
A separate Continental-Turbomeca Palouste gas turbine provided 1.1 kg/sec. (2.5 lb/sec.) of thrust for the reaction-control system
used in the vertical flight mode.
As in other VTOL aircraft, the ATV required two sets of control mechanisms - one for flight in the helicopter-like vertical mode,
and the other for conventional horizontal cruise flight, which relied on standard airplane controls. When the aircraft was hovering or
in slow flight, exhaust ducts on the wingtips provided roll control, while an assembly of valves and exhaust pipes mounted on the tail
provided pitch and yaw control.
Bell completed the ATV in December 1953. In January 1954, test pilot David Howe made the first flight while tethered to the ground
to prevent an inadvertent loss of control while testing the highly experimental control system. During a flight in February, a
compressor disc failed while the ATV was hovering, resulting in a fire and significant damage to the aircraft. Fortunately, Howe
escaped injury. Bell engineers quickly made repairs, and the test flights resumed. The first free flight occurred on November 16,
1954. By early 1955, the performance limitations of the aircraft led to the termination of the program after only 4.5 hours of operation
with the ATV.
The slow response of the early gas turbine engines was one of the greatest inherent flaws in the ATV and other VTOL designs of
the time. These engines were necessary for their power-to-weight ratio, but they were unsuited for the numerous power adjustments
required for hovering. The ATV's J44s also produced a meager 998 kg (2,200 lb) total thrust, which was nearly equivalent to the
aircraft's gross weight. The lack of thrust prevented a full transition from the vertical to horizontal flight modes, which resulted in the
temporary installation of conventional wheeled landing gear to allow tests of the horizontal flight characteristics of the aircraft.
The ATV project's greatest contribution was the generation of data, which formed the basis of Bell's next jet VTOL project, the
X-14 (known inside Bell as the Model 68). The design for this aircraft emerged several months after the termination of the ATV
program. The X-14 differed greatly from the ATV as it used moveable exhaust ducts to vector thrust from powerful
fuselage-mounted engines, but the vertical reaction-control system was similar.
The X-14's vectored thrust approach to vertical flight eventually found widespread acceptance when it was adopted for use in the
Hawker-Siddeley Kestrel (see NASM collection) and its later developments. The X-14 provided a vast amount of VTOL data for the
National Aeronautics and Space Administration (NASA) before incurring damage in a 1981 crash. Neil Armstrong once flew it as a
Lunar-lander trainer.
The ATV was not a successful test aircraft, but it provided considerable insight to the challenges of producing jet VTOL designs.
With the data it provided, Bell was able to improve upon the concept and make a substantial contribution to the VTOL field.
Wingspan: 7.93 m (26 ft)
Length: 6.31 m (20.7 ft)
Height: 2.35 m (7.7 ft)
Weight: Gross, 908 kg (2,046 lb)
Engines: (2) Fairchild J44 turbojets, 499 kg (1,100 lb) thrust
(1) Continental-Turboméca Palouste [for vertical control jets
Wat dit toestel verder bijzonder/vreemd maakt is dat de passagiers (2) naast elkaar op een bankje zitten in de voorste cockpit.
Verder is de radiator onder de bovenvleugel typisch voor deze ontwerpers/bouwers van die tijd.
Dit vliegtuig maakte een zeer goede indruk tijdens de Ford Air Tour in 1925 :) En in 1926 werden verschillende toestellen van dit model eerste in hun category tijdens de National Air Races. :rolleyes:
Status
