M
MeX101
Neem nou gewoon die 40amp turnigy plush, de motor kan je de originele nemen of de 850kv die wat sneller is die trekt 35amp dus een 40amp regelaar is dan goed.
De orgineel HobbyKing R/C Hobby Store : hexTronik DT750 Brushless Outrunner 750kv
anders misschien deze die heeft wat meer kv en power
HobbyKing R/C Hobby Store : D4023-850 Out Runner Motor
edit:
for less than $1 more you can replace this motor with the (D4023-850 Out Runner Motor). would deffinately recomend this as an upgrade. you would get a max current of 35amp instead of 8amp. 850kv instead of 750kv means more speed if u want it. and its only about 25grams more.. and with the same mounting plate it would be a straight and easy swap. for the esc i would use at least a 40amp esc to stay safe. maybe the hobbking ss 40-50amp esc for only $10.. this is what i would do anyway
edit:
