Specifications:
KV:1570
Max Efficient Currency:9A
Recommended Working Currency: 7A - 20A (Efficiency higher than 75%)
Weight: 68g / 2.4oz
As diameter: 3.0mm Prop: 8X4 APC-E/ 9X4.5 APC-E
Recommended Applications:
a. 3 cell Lipo: APC 8x4SF 11100RPM 10V 20A Thrust 805 gram
b. 3 cell lipo: 9X4.5APC-E 9900RPM 10V 23.8A Thrust 960 gram
The power output of the motor is equal to a OS 15LA nitro Engine, can be used for all 10-15 class nitro powered airplanes. Using 2000mah-2200mah Lipo, 20A above electric speed controller, the total weight of the power system is less then 20% of Nitro power system.
De klapschroef van mijn space scooter is er aan!
Noah zei:heb er nog wel in de aanbieding.. dat is het eerste wat van de scooter afgaat... die klapprop..
