F
fireforx309
misschien eens een mailtje richting fabrikant ivm het mankement?
zou niet mogen.
zou niet mogen.
...maar krijg ik geen spraak.
Staat de vario wel op het zelfde kanaal als je radio?
Ah, snap ik het goed dat het geluid van de Vario wel uit je radio komt (de daal- en stijg tonen), maar de spraak niet?Het kanaal staat goed want de vario doet het.
Maar de spraak doet het niet.
Kortom, het kan een kapotte geheugen module zijn. Reparatie kost 5 euro in 2011 (Nu dus 5,20 Eur...Re: Problem by getting speech
by Pitlab » 8 Sep 2011, o 09:43
Hello JuhaJreinikka wrote:I'm trying to set my new SkyAssistant in finish language, but no proper results until yet. I made following steps:
1. Update firmare version 2.33.3, FI (found in Pitlab website)
2. Samples -> Save on SkyAssistant -> "Sample_fi.saw" (newest version found from Pitlab website)
3. Turn device off and on again
4. wait until started 30sek (Beebs in every 3sec)
No speech at all, but variometer is working good. Tryed allso Configuration -> Restore default settings but no effect. I've tryed with English and germany languages (firmware and .saw) too, but allways the same result. Every time it should say someting, I only hear a very short and quiet "click".
Is it defect or did I something wrong?
I am sorry for late ansver.
You are doing good. It looks like memory failure. Most problably valriometer also don't register logs.
The memory chip storing voice samples and log is in QFN version (without pins, only soldering pads) and is sensitive for mechanical stress. Maybe you bend variometer PCB during landing or crash and connection to memory pads into the chip were cracked.
Please send it to me for repair. Cost of replace memory chip is 5 Euro.
