Shaul Eiz .. heeft de ontwikkeling overgenomen.
Download van de laatste versie:
http://n.ethz.ch/student/mmoeller/fms/alpha/smartpropoplus.zip
( < 400k)
The 'README' file:
SmartPropoPlus - Using your Transmitter as a Joystick for FMS
This package contains 5 different files named winmm.dll.
They are located in separate folders under folder "bin"
You have to copy appropriate file into the folder where file FMS.exe resides.
If you are using any PPM transmitter (which is the most common) - copy the file that is
inside "PPM"
If you use a Futaba PCM transmitter - copy the file that is inside "Futaba_PCM"
If you use a JR PCM transmitter - copy the file that is inside "JR_PCM"
If you use a SANWA or Airtronics PCM transmitter - copy the file that is inside
Sanwa_PCM1 or Sanwa_PCM2 according to the modulation type.
If you are not sure, try all 5 files one-by-one until you succeed.
Lees de PDF: 'SmartPropoPlus' dat geeft heel goede technische info.
De 'sources' zijn er ook bij !
Phil.
keywords: simulator fms kabel audio mike mikrofoon pc dll joystick zender plug jack
( < 400k)
The 'README' file:
inside "PPM"
Phil.
