even googlen en je vindt het volgende:
This is the Tamiya Forward and Reverse Electronic Speed Control.
FEATURES: Compatible with Tamiya 540 and Sport Tuned stock motors
Reverse function can be changed to brake for races where reverse is
not allowed
Compatible with Futaba, Tower Hobbies, Tamiya, KO, JR and Airtronics
Z connectors
Set button allows adjustment of maximum forward and reverse throttle
trigger settings
INCLUDES: One Tamiya Forward and Reverse Electronic Speed Control with motor
connectors, Kyosho style battery connectors, receiver connector
and receiver switch pre-installed, instruction sheet
REQUIRES: Installing in vehicle and connecting motor and battery
SPECS: Length: 1.6" (40.7mm)
Width: 1.4" (36.8mm)
Height: 0.88" (22.5mm)
Weight: 1.9oz (54g)
Control System: High frequency drive
Max Continuous Current (FET Spec): Forward 60A, Reverse 60A
Power Supply: 7.2V (with 6 cells
Output Voltage for Receiver: 7.2V (BEC)
Output Current for Receiver: 1A
