Klopt, puur theoreties gezien haal je grip weg. Maar je auto zo er beter over "kerbstone's" en hobbels mee kunnen. Ook zou hij minder snel last moeten hebben van griprolls.
Anti-roll bars are best used on tracks where traction is consistent.
Adding an anti-roll bar, or stiffening it, reduces traction at that end of the car. So it feels like the opposite end has more grip.
If the track is smooth enough, it also makes the grip level feel a little more consistent.
Anti-roll bars reduce body roll in turns, so they make the car feel more direct, and make it change direction quicker.
Stiffer Front:
An anti-roll bar at the front of the car reduces low-speed steering. The turning radius will be larger, but smoother and very consistent.
It reduces 'hooking' by preventing front end roll.
The car will have more rear traction in turns.
Stiffer Rear:
Adding an anti-roll bar to the rear of the car gives more steering. the car steers tighter, also at low speeds.
On a very smooth track, it can make sliding easier.
