KOLDERSTOK BATAVIA / HAARLEM
Discussie in 'Bouwverslagen historische schepen' gestart door Heinrich, 28 feb 2020.
  1. Heinrich
    Heinrich
    26 jan 2020
    China
    @Ronk Thank you Ronk.
  2. Pingu57
    Pingu57 Forum veteraan
    14 dec 2014
    Leeuwarden
    Een mooi stukje knutselwerk Heinrich.:rofl::rofl:
    Heinrich vindt dit leuk.
  3. TIMBERWOLF
    TIMBERWOLF Forum veteraan
    28 aug 2008
    noord-holland
    :thumbsup::thumbsup:
  4. Marcus Botanicus
    Marcus Botanicus
    20 mrt 2015
    Crown Point, IN, USA
    Heinrich,
    Good looking planking exercise. I love the lines from the Bowman Swallow steam boat.
    Marcus
  5. Hans Groenenberg
    12 nov 2014
    Oud Beijerland
    Netjes hoor HEINRICH!
  6. Heinrich
    Heinrich
    26 jan 2020
    China
    @Marcus Botanicus Thank you, Marcus. The Bowman Swallow is a perfect example of "less is more". I was also attracted to it at first, by its very clean and elegant lines. The bigger Seahawk with a twin steam engine is even more beautiful. :)
    Marcus Botanicus vindt dit leuk.
  7. Heinrich
    Heinrich
    26 jan 2020
    China
  8. Heinrich
    Heinrich
    26 jan 2020
    China
    Hello Everyone
    Time for a decent update. Yesterday I had the day off and had (by my slow standards) a very productive day. So to kick off this post just a status quo picture of where I am at the moment before work commenced.
    With my replenished wood supply from Kolderstok having arrived, it was time to complete the coloured wales on the starboard side. I have to point out that me having to order extra wood is by no means an oversight on Kolderstok's part. I have purposely used the 4mm walnut strips for certain parts of the build where I should have used basswood.
    With that done it was time to remove the protruding bulkheads from the deck.
    During the installation of the wales, great care was taken not to apply glue to these parts of the bulkheads; so removing them was a simple task by using a pair of pliers to snap them off at the base. Even so, it was quite strange breaking something on purpose after you have taken such great care during the building process not to. :)
    The remaining stubs were simply sanded flat to deck level. Next the waterway was constructed from two 4mm x 1mm slats glued squarely to each other and then painted black. These two strips were then glued into position on both sides.
    Next I finally placed the half deck into position and glued the grating in its cut-out. The gratings: Trial and Error - far more "error" than "trial". However, I finally had something that I was happy. I stained it with the Dark Oak water-based stain that Hans has so kindly provided me with Free of Charge and was pleasantly surprised at the result. At first I thought it was far too dark, but seeing it on the ship - especially after I had planked the Half Deck - changed my mind completely.
    Half deck with grating and the two black half-walls are installed. As can be seen these are also constructed of overlapping planks in clinker-style.
    As it was not yet bed-time, I placed the walnut border around the front deck cut-out and started to commence with the planking.
    And when dawn broke this morning ...
    Voila !
    Thank you all for following the build, all your positive comments and suggestions. Hans says his kits have a "gripping factor". Yesterday, for the first time - in a very long time - I lost myself in this build and became fully immersed in what I was doing. A rare, and most pleasant feeling.
    Keep well everyone and take care.
    Friendly greetings - Heinrich
    Bijgevoegde bestanden:
    Hoosterw, janzwart, TIMBERWOLF en 7 anderen vinden dit leuk.
  9. Stephan Kertész
    Stephan Kertész
    5 jul 2019
    Ittervoort
    Great job
  10. cees050
    cees050
    16 mrt 2016
    kop van drenthe
    wordt erg mooi Heinrich
    gr Cees
  11. Ronk
    Ronk
    13 dec 2019
    Helena Geertje
    Die geel en rooi gee baie kleur meer!
  12. *Hans*
    30 okt 2012
    Dordrecht
    De Kolderstok beits is op terpentine basis en kan/mag daarom niet naar het buitenland gestuurd worden. Ik moest Heinrich dus in eerste instantie teleurstellen. Ik kwam echter in mijn werkplaats nog een brouwseltje tegen wat ik gebruikt had voor het kleuren van touw (en wat niet werkte). Dit was een beetje aan de kant geraakt. Een kort testje op hout gaf echter een heel mooi resultaat en omdat dit op waterbasis was kon ik een klein flesje meesturen met het pakket naar China.
    Ik ga daar toch weer eens verder mee experimenteren.
    Marcus Botanicus, Heinrich en Montgomery vinden dit leuk.
  13. cees050
    cees050
    16 mrt 2016
    kop van drenthe
    Ikzelf gebruik Clou waterbeits is een poeder wat je oplost in heet water. en geeft hele mooie kleuren.
    Groet Cees
  14. Stephan Kertész
    Stephan Kertész
    5 jul 2019
    Ittervoort
    azijn met roestige staalwool, cacao, koffie, thee, donkere houtsnippers etc.....
    Marcus Botanicus en Heinrich vinden dit leuk.
  15. TIMBERWOLF
    28 aug 2008
    noord-holland
    :worship:
  16. Jaques
    Jaques Forum veteraan
    31 mei 2016
    Tilburg
    Tja dat zijn van die variabele momenten die je tijdens het bouwen weleens zonder erg vergeet....
    Toch niet heel de nacht doorgewerkt hee......
    Nee hoor Heinrich, alle gekheid op een stokje, je bent hier een mooi model aan het maken wat ook steeds meer jou interpretatie weergeeft van de “Haarlem” :wave
    Knap hoor en zo met die donkere roosters zie je het ook steeds minder “Batavia” worden en meer jou “Haarlem”, met een beetje van Kolderstok en steeds meer Heinrich.....
    Succes verder en uiteraard blijf ik je met veel belangstelling volgen
    Gr Koos
  17. Heinrich
    Heinrich
    26 jan 2020
    China
    @Stephan Kertész Thank you for the compliment, Stephan! The azijn and staalwol is something that I still want to experiment with on the decks - although I must say I really like the light colour of the Abachi just as it is now.
  18. Heinrich
    Heinrich
    26 jan 2020
    China
    @cees050 Thank you, Cees. I am glad that I made some visible progress yesterday - it's good for the motivation!
  19. Heinrich
    Heinrich
    26 jan 2020
    China
    @Ronk At first, I wasn't so sure of the maroon - but now I think it gives more of a "relaxed" look instead of the sharp contrasting yellow and red. So, I am very happy if you look it too. Vele dank.
    Ronk vindt dit leuk.
  20. Heinrich
    Heinrich
    26 jan 2020
    China
    @*Hans* I certainly think it is worth experimenting with. Because I used the 3mm Abachi strips for the rooster, it was very light in colour, so I didn't want to thin the beits - I used it straight from the bottle - and only one layer. When it comes to the romp, I will certainly play around with diluting it to see what the effect is on the walnut.
