Hello together,
well, what can I say, a thread heats unfortunately the very cool and I wanted me to compare or from discussions raushalten. I will now but some of the experiences and insights I get rid of the Vstabi and in recent months with the AC-3X made. Unfortunately, I have to but something first.
I have been more than three years paddellos with Vstabi and was on the flight performance so far achieved very satisfied. By the time you get a good feeling about how the behavior of the helicopters is to interpret and can also be a more or less unknown helicopter and leaves the conduct of the Stop Helis from stationary cyclical movements neutral setting, ie After a while commuting eliminate snaps. The Anti Osszilation filter is very effective. The Aufbäumneigung of helicopters in fast forward flight, especially in advanced mode effectively suppressed. If you look at the rotor blade election some trouble, and a neutral to the rotor head and the appropriate cushioning sheet, you can even at high speeds and defines neutral taxes. If you leaf in the election but bad luck and has a rather aufbäumendes or unterschneidendes rotor blade mounted, so I had more with the problem that with increasing speed and pitch much in a certain sponginess Nick halt what the tax codes makes something toxic and Nick abrupt movements to a certain reverse commuting. If you have caught a leaf, then unfortunately, not entirely roles on a line drawn but sometimes corkscrew. One can but with such a sheet still be happy if one pressure sensor flies. It controls speed and pitchabhängig Nick and compensated for the Aufbäum or sub-cutting trend. I have more or less speed incorporation then almost always a feeling for my fairly neutral behavior when straight loss can achieve real and was also satisfied.
The slight remaining sponginess that much speed I sometimes have observed and a simple cutting and reverse flies that I have ever observed by helicopter, I have no further questions, I have this to the limited power of servos and the aerodynamics of my hood succession. But that was not really disturbing.
What the rolling behavior contexts, especially when I reverse roles in some of my Helis noticed that I almost without him deliberately to control a very large roller circle flown bin. This behavior is also blattunabhängig.
What I meant wish is that I actually V-stability and was satisfied with the above observations could live.
The first is what I to V would say stability. The AC-3X is in many respects different to what I of V-usual stability. I mean now less the user interface or the single structure, I think everyone can own his views, but above all, the concept behind AC-3X.
When AC-3X is the first time Heli on the table before mechanically set and optimized so that the leverage ratios are such that the servo resolution well exploited. This is just in every possible Taumelscheibenregelung important to good tax properties to maintain and therefore I was just not surprised.
The Aha experience came to me on the course. I can conduct the flight with just describe neutral. The Piros from the tube are neutral as a paddle head. The roles are in both directions and just spout the line at full speed is very well aware if you pitch pipes. Loops, which I like to fly high, are only limited by my eyes and the maximum speed straight through the fall of the engine or a flow demolition.
The rest shuttle behavior is free although I sheets and other servos as Stefan fly.
What I compared with the standard setup adapted, is basically just the Expo, which is separated for TS and stern in the AC-3X set.
It is not surprising that AC-3X on the Shark / SE goes well, for it is mainly yes. I have therefore now also tested several other helicopters so far and am always on the same conclusion: If you can contribute to the setting in the basement mechanical trouble, then the TS works well at first. At the rear you have to, depending on the translation control rods, rear translation and speed the P-sensitivity.
The rear performance I think after I Expo in the transmitter weggedreht have very good. The Pirokonstanz for me from the V-stability not distinct. It is interesting to the possibility Pirobeschleunigung and Abstoppverhalten set to be separated. It can be very effective with Piroraten.
One thing I noticed is also positive is that the flight characteristics almost Regardless sheet. I have here a series of leaves with different lead but the same weight. The fly almost the same. Even if the leaf weight increases, notes no major change in the tax behaviour but only that the engine at high cyclical rates rather choke on.
As already mentioned, has AC-3X so was not as a bank switching, with the parameters changed. I miss but not de facto because I simply have not changed. I voted rumgespielt and the only thing to be noticed is that the TS sensitivity in a fairly wide range can shrink without the man was noticing. If they increase, the helicopter at some vague, but it starts to not to commute long as the mechanical Anlenkung as in the manual is set. I therefore take advantage of the speed switching nor even really thought the sensitivity channel but fly with a fixed sensitivity. I think we must, even if I did not initially believe could make them free, all concepts that always the same. The manoeuvrability is also largely speed Independent. I like that, so I can 1450 with beautiful 3D fly. If you want to influence the agility, make of the dual rate.
Another point which is remarkable for me is that an AC-3X as the other flies. Stefan calibrated sensors each individual AC-3X and axles, the sensor to the casing. That is my understanding the reason for the neutrality and something that I no longer want to miss.
As you can see, I am now quite satisfied with the AC-3X. Überinterpretiert but please do not. I have tried in the functional description objectively.
I am also convinced that the development of Vstabi, AC-3X and other rules go further and only my impression is instantaneous!
To Gyrobot, Lutz, with your even want a comparison, I can not say much. Timos videos I've seen and it was, as always, very impressive.
Many greetings
Christian
