bouwverslag super bandit park jet
  • Topicstarter Topicstarter denny
Heb op internet wat gegevens gevonden.
Over wat voor motortje voor een microfan
- Jamara 280 Pro 7 Sanyo. 7,90 Volt 5,00 A 20224 U/min 40 Watt 66 gr. 19,8 m/sec.
- Jamara 280 Pro 8 Sanyo. 9,30 Volt 6,40 A 22930 U/min 60 Watt 84 gr. 22,3 m/sec.
- Jamara 280 Pro 9 Sanyo. 10,30 Volt 6,70 A 24580 U/min 69 Watt 96 gr. 23,9 m/sec.
- Jamara 280 Pro 10 Sanyo. 12,00 Volt 7,30 A 27779 U/min 88 Watt 117 gr. 26,4 m/sec.
- MPX 280BB 7 Sanyo. 8,20 Volt 4,80 A 20580 U/min 39 Watt ?? 69 gr. 19,7 m/sec.
- MPX 280BB 8 Sanyo. 9,50 Volt 6,50 A 22762 U/min 62 Watt 89 gr. 22,9 m/sec.
- MPX 280BB 9 Sanyo. 10,50 Volt 7,90 A 25180 U/min 83 Watt 104 gr. 25,9 m/sec.
- MPX 280BB 10 Sanyo. 12,40 Volt 8,60 A 28054 U/min 107 Watt 128 gr. 28,3 m/sec.
- MPX 280BB 12 Sanyo. 13,50 Volt 10,60 A 31231 U/min 143 Watt 155 gr. 32,4 m/sec.
- Speed 300 7 Sanyo. 7,60 Volt 9,10 A 29123 U/min 69 Watt 142 gr. 19,7 m/sec.
- B20-18L 7 Sanyo. 8,20 Volt 3,00 A 23311 U/min 25 Watt 3000 U/Volt 79 gr. 21,7 m/sec.
- B20-18L 8 Sanyo. 9,40 Volt 4,10 A 27943 U/min 39 Watt 107 gr. 25,2 m/sec.
- B20-18L 9 Sanyo. 10,80 Volt 5,20 A 30914 U/min 56 Watt 137 gr. 28,5 m/sec.
- B20-18L 10 Sanyo. 12,10 Volt 6,10 A 33941 U/min 74 Watt 164 gr. 31,2 m/sec.
- B20-18L 12 Sanyo. 13,70 Volt 7,40 A 38243 U/min 101 Watt 215 gr. 35,8 m/sec.
- B20-18L 14 Sanyo. 16,50 Volt 10,20 A 46298 U/min 168 Watt 329 gr. 44,2 m/sec.
- B20-18L 16 Sanyo. 18,40 Volt 12,20 A 51651 U/min 224 Watt 406 gr. 49,1 m/sec.
- B20-15L 7 Sanyo. 8,00 Volt 4,70 A 27361 U/min 38 Watt 3700 U/Volt 116 gr. 26,3 m/sec.
- B20-15L 8 Sanyo. 9,40 Volt 6,50 A 32104 U/min 61 Watt 154 gr. 30,3 m/sec.
- B20-15L 9 Sanyo. 10,70 Volt 7,70 A 36168 U/min 82 Watt 205 gr. 34,9 m/sec.
- B20-15L 10 Sanyo. 11,90 Volt 9,30 A 39684 U/min 111 Watt 251 gr. 38,6 m/sec.
- B20-15L 12 Sanyo. 13,30 Volt 11,40 A 43575 U/min 152 Watt 303 gr. 42,4 m/sec.
- B20-15L 14 Sanyo. 15,90 Volt 15,10 A 51103 U/min 240 Watt 416 gr. 49,7 m/sec.
B20-12L, 10x500AR, 11-12A, 43-44kRPM (thrust 320-360g estimate)
Hier zie je een aantal gegevens.
Mocht het zijn dat toevallig die B20-15L van hacker je aanspreekt, ga dan snel naar de volgende site. Daar is er nog eentje 2e hands te koop. Borsteloze motoren verslijten nauwelijks (mits men er goed mee omgaat). En een hacker is normaal niet goedkoop, dus misschien kan je je voordeel ermee doen.
http://www.mfis.net/microflight/shop/product_info.php/cPath/24/products_id/427
groeten Paul
max 55A, en dan op een 2Winder.
Dat wordt een korte levensduur. Ik gebruik kokam 3200mAh 20C. Dat is 64A, en deze komen er al aardig warm uit nadat ze mishandeld zijn door de 2winder in een minifan. En dan heb ik nog een marge van 11A.
Is het trouwens bij die cellen van jouw niet, dat ze continu 35A kunnen leveren, en pieken van 55A.
Als dat is, dan moet je het niet doen. Als de motor 52A trekt (de 2winder), dan moet je ook zorgen dat je lipo's hebt die dat continu kunnen leveren.
Kun je eens aangeven welk merk lipo's je hebt? Want waar heb je de data vandaan dat ze 25C kunnen hebben. Heb namelijk nog nergens 2200 mAh cellen gezien die 25C aan kunnen continu.
groeten Paul
Dat klopt, een wemotec 480 fan, is geen micro
De wemotec 480 is 70mm doorsnede.
De micro fan is 50mm doorsnede.
En de motoren van een wemotec 480 fan passen niet in een micro fan.
ik denk dat je ook beter een setup kan verzinnen voor een micro fan. Dadelijk raden mensen je iets aan, wat je moet aanschaffen. Jij je centen erin gestoken, en dan bevalt het niet.
En zoals eerder aangegeven, heb je al iets in gedachte? welke lipo je gaat gebruiken bijvoorbeeld. Want als je al een lipo hebt, en je wilt die gebruiken, dan kan je uitrekenen wat hij maximaal aan stroom kan hebben. En dan weet je of je bepaalde motoren wel of niet geschikt zijn voor jouw lipo.
Als ik hierboven in het schema kijk, dan spreekt mij die B20-15L wel aan, en dan op 3s1P.
Maar dat is net, wat wil je? wil je heel veel power (hoge stromen, korte vliegtijd). Of langere vliegtijd, en lagere stromen.
Als die B20-15L je wat lijkt, die is 3700KV. Op die site van rctechnics staan genoeg motoren die hier net boven of onder zitten. Misschien dat je daar dan eens naar moet kijken. Zelf ken ik die motoren niet, dus welke goed is en welke slecht, geen idee
ik heb er een mini fan in liggen met een alighn 3200kv motor die combinatie trekt 18A en mijn lipo,s zijn 3sp1 1800 mah en 20C kan makkelijk dus
maar dit is wel voor de grotere minifan versie heb ook nog 2 micro,s liggen dus als dit wil vliegen ook maar een kleinere versie bouwen
heb dit draadje in jouw topic gepost laten we ze wel apart gaan houden want er komt na deze ook nog een f14 bouwverslag
ps heeft iemand al een tip voor mijn inlet tube ben er nog niet uit hoe ik deze moet maken ik krijg de overgang van 4kant naar rond niet goed heb voor die overgang maar een cm of 5 a 6
Euh, mischien zon plastic drinkbekertje pakken? Die kun je aant uiteinde wel tot vierkant vouwen, eventueel met kleine stukjes balsa een framepje lijmen?
moet het wel een milkshake beker worden vanwege de diameter
mmm plots zin in een shake ben effe naar de vettent
bedankt
@denny,
Kan je me eens de maten geven van de inlaat.
Dus van voren gezien, de lengte en breedte graag. Wel aan de binnenkant gemeten.
Ik zal hem dan eens proberen in 3d te tekenen, en dan als het goed is, kan ik daaruit weer halen hoe de inlaat gemaakt moet worden. (tenminste hoop ik, ben pas begonnen met het 3d gebeuren, dus ben geen held erin)
groeten Paul
P.S. heb jij de 109% versie?
@denny,
groeten Paul
dubbelpost :P
verveel me
moet w8te tot alle lijm droog is.
denk dat ik alvast begin met schuren van de vleugels
hoe breed was jouw achterkant van de romp sietse?
het punt waar de lcuhtstroom eruit komt.
bij mij 4,3 cm
Ja dubbelpost, komt door het irritant geval van modelbouwforum hiero.
Het is de laatste tijd al #$%^&* de verbinding. Dan doet hij het goed, en dan ligt het ineens plat.
Irriteer me gek aan, wil je iets doen, werkt het niet mee
he danny ik heb een iedee voor dat van 4 kant naar rond
gewoon niet! 8)
maak gewoon 2 rondjes in de luchthappers en dan voeg je ze samen.
misschien werkt het misschien niet.
maarja dan heb je dat lucht aan de voorkant van de luchthappers ernaast gaat. probleem verplaatst zich.
zodra je iets hebt laat het ff weten oke? :| :wink:
ongeveer 6 cm lang lxb=9.2mmx7.2mm en voor een mini fan
dank je je hulp is zeer welkom daarom vind ik het forum geweldig
heel nederland denkt met je mee
ben ff aan de luchtbuis begonnen.
snap er nix van.
lukt niet echt
alleen het achterste gedeelte van 5 cm versmalle naar 4,3 cm iemand iedeen?
gewoon rond om je fan vouwen en aan het eind iets strakker draaien 2 tapes en je bent klaar
