FORUMLEDEN met NOSTALGIE......"vreemde" kisten
Status
Deze opgave is moeilijk, gelukkig :D
Maar je weet het nooit zeker.
Morgen de eerste hint als het nog nodig is. ;)
Deze begint er op te lijken, maar is het nog net niet:
Marco weer terug van weggeweest ;)
Toen ik deze opgave plaatste dacht ik meteen, deze is voor Marco. :thumbsup:
Toestellen (gemotoriseerd) met een grote vleugelslankheid ken jij volgens mij allemaal. :D
Nu ben ik nieuwsgierig waarmee jij ons gaat verrassen. ;)
Nog een interessante link.
EMERALD Projects
http://en.wikipedia.org/wiki/A-14_Shrike
Curtiss XA-14
The Curtiss XA-14 was a 1930s United States airplane, the first multi-engine attack aircraft tested by the United States Army Air Corps. Carrying a crew of two, it was as fast as the standard pursuit aircraft in service at the time.
Contents
* 1 Design and development
* 2 Specifications (XA-14)
* 3 See also
* 4 References
Originally built as an in-house venture as the Curtiss Model 76, powered by two experimental Wright XR-1510 radial engines, flight testing was sufficiently impressive that after the USAAC appraisal the Model 76 was returned to Curtiss and fitted with two 775 hp (578 kW) Wright R-1670-5 Cyclone engines with constant-speed propellers. This configuration was accepted by the Army with the designation XA-14.[2] It had standard Army markings with the serial number 36-146.[3]
The Model 76 was of all-metal construction with an oval section semimonocoque fuselage, described as "pencil slim". The XA-14 was extensively tested, at one stage being fitted with a 37 mm (1.46 in) nose cannon.[4]
In July 1936 thirteen (serial numbers 37-52 to 37-64) developed versions, re-engined with two Wright R-1820-47 Cyclone twin-row radials, were ordered into production as the Y1A-18.
Tupolev ANT-63P (Tu-1)
An attempt to produce a radar-equipped three-seat long-range night and all-weather fighter also suited for the escort mission, the ANT-63P, alias Tu-1, was one of a number of progressive developments of the ANT-61 (Tu-2S) bomber. Initially powered by two 1,900hp Mikulin AM-39F 12-cylinder liquid-cooled engines, the ANT-63P (the suffix letter indicating Perekhvatchik, or "Interceptor") carried a fixed forward-firing armament of four 23mm cannon, two in the wing roots and two in the lower forward fuselage. The nose was intended to accommodate a PNB-1 Gneiss-1 airborne intercept radar based on the German FuG 220. First flown on 30 December 1946, the ANT-63P attained 680km/h and demonstrated a range of 2500km. Official interest in piston-engined fighters was waning by this time, and although the ANT-63P was re-engined with 1,950hp Mikulin AM-43V engines driving four-bladed propellers, being tested in this form in December 1947, no production was undertaken.
Ho,ho, niet zo snel jij! ;)
Volgens mij heeft die Tupolev aan beide zijden van het wiel een wielsteun lopen, terwijl de kist in de foto van de opgave een enkelzijdige wileafsteuning heeft.
(Da's ook het enige verschil dat ik zo snel kon ontdekken)
Geen Tupolev dus.
MIG-5
Probably the most incorrectly reported Russian aircraft. The name“MIG-5” was reserved, however it was actually a twin engine aircraft which never used the MIG-5 designation. This plane was given the designation MIG-DIS-T. Only two were built and the entire MIG-5 production was quickly cancelled. The MIG was having a rough time getting started. The inconsistent modifications of the MIG-5, variants of the MIG-1, then the confusion of introducing the twin engine “escort fighter,” led to the cancellation of the whole program. As far as we know only two MIG-5 variant of the MIG-3 were built. They were never used.
Bij deze mijn fout herstelt!
Wat een instinker zeg!
De fabrikant van dit toestel is een grote bekende onder de modelvliegers.
Tenminste één van zijn toestellen wordt veelvuldig nagebouwd.
Johannes
Status
