Mijn eerste GR130
I am struggling, pulling hairs but also having fun :)
Do you have any input on a good hall sensor to use / magnet part number?
I am using a generic U1881 hall sensor and some small magnets for testing purposes (2x2mm) but this configuration is not powerful enough to detect RPM from <30mm distance the turbine will require.
Thank you, hopefully the magnets will arrive soon.
What functions have you been able to incorporate into your ECU? Streaming data and/or functions?
Thank you very much!
Sent you an email Ray :)
ECU Monitor prototype one solid step furter :). Step 1 complete.
Next step in this department is to emulate a servo and let it drive the PWR value and govern voltage for the fuel pump :)
To make a ground station to operate the turbine, without a radio ;)
At the moment I don't have one as I sold my MC24 off a few years back. :rulez:
Hehe, certainly possible and I haven't carved anything in stone yet :). I am waiting for Mosfets to drive a fuel pump, just got to make the pump first :hammer:
Minor update, no pictures yet.
The stainless steel needles arrived (5pcs 180mm long) so now I switch drive from software to hardware :)
Next up will be learning how to braze brass/steel together! The evaporator sticks are cut to length and I need to form their flanges prior to spot welding these to the CC ring. Hopefully the CC and fuel delivery system will be completed this week :D
First time for everything, finally found some time to braze the brass tubing and fuel sticks :)
Went alright, just needed to apply enough heat and allow the heat to soak properly. Used a MAP-torch for the job.
One of the 6 sticks is a little weaker (the "middle one " in the first pic) than the others, might redo that one.
