heey,
ik kon er nog niks over vinden hier.
ik maak er gelijk maar het grote slash topic van zodat er geen rommelige losse topics met vragen ontstaan.
ik vind het een super vette auto!
hij is al verkrijgbaar voor ongeveer 199 dollar excl. verzending.
heeft iemand hem al?
SPECS,
Length 22.36 inches (568mm)
Front Track 11.65 inches (296mm)
Rear Track 11.65 inches (296mm)
Weight 76.2oz (2.16kg)
Height (overall) 8.425 inches (214mm)
Wheelbase 13.2 inches (335mm)
Front Shock Length Long
Rear Shock Length XXLong
Front Tires Slash 2.2"
Rear Tires Slash 2.2"
Front Wheels 2.2" Satin-Finish
Rear Wheels 2.2" Satin-Finish
Speed Control Type Waterproof XL-5 ESC
Motor (electric) Titan® 12T 550 (12-turn)
Gear Ratio (internal) 2.72 (final drive: 12.58)
Differential Type Steel Composite Planetary
Gear Pitch 48-Pitch
Transmission Metal Gear Magnum 272™
Steering Bellcrank
Chassis Type Modified Tub
Chassis Material Composite Nylon
Top Speed 30+mph*
Skill Level 1
XL-5 (WATERSEALED) SPECIFICATIONS
Input voltage: 4-8 Cells (4.8 to 9.6 Volts DC)
Case Size: 1.23"W x 2.18"D x 0.61" H
Weight: 2.44 Ounce
Motor Limit: 15-turns** (540 Size)
12-turns** (550 Size)
On Resistance Forward: 0.007 Ohms
On Resistance Reverse: 0.014 Ohms
Peak Current - Forward: 100A
Peak Current - Reverse: 60A
Braking Current: 60A
Continuous Current: 14A
BEC Voltage: 6.0 VDC
BEC Current: 1A
Power Wire: 14 Gauge / 5"
Input Harness Wire: 26 Gauge / 9"
Transistor Type: MOSFET
PWM Frequency: 1600 Hz
Thermal Protection: Thermal shutdown
Profile selection:
Sport Mode:
100% FWD, 100% brakes, 100% REV
Race Mode:
100% FWD, 100% brakes, no REV
Training Mode:
50% FWD, 100% brakes, 50% REV
Single-button setup: Yes, Traxxas EZ-Set®
SPECS,
Gear Pitch 48-Pitch
Steering Bellcrank
Top Speed 30+mph*
Skill Level 1
Weight: 2.44 Ounce
BEC Current: 1A
Profile selection:
Sport Mode:
Race Mode:
Training Mode:
