Hieruit maak ik op dat de failsafe instellingen bepaald worden tijdens de bindprocedure. Als je pitch op dat moment vol negatief stond dan zal dit dus ook zo zijn als de AR7200BX in failsafe modus gaat.To bind an AR7200BX to a DSM2 or DSMX transmitter:
1. Insert the bind plug in the BND/DAT port on the receiver.
2. Power on the receiver (The AR7200BX can be powered through any open port). The H LED on the AR7200BX and external remote receiver (if connected) should be flashing, indicating the receiver is in bind mode. To bind a helicopter with an electronic speed controller that powers the receiver through the throttle channel, insert the bind plug into the BND/DAT port in the receiver and the ESC lead into the throttle (THRO) port.
3. Move the sticks and switches on the transmitter to the desired failsafe positions (low throttle and neutral control positions).
4. Follow the procedures of your specific transmitter to enter Bind Mode. The
system will connect within a few seconds. Once connected, the H LED will
turn off and the AR7200BX will start the initialization process.
5. After setting up your model, rebind the system so the true low throttle positions are set in the failsafe.
6. Remove the bind plug from the BND/DAT port on the receiver before you power off the receiver and transmitter. Store the bind plug in a convenient place
Dat bevestigt wat ik hierboven al dacht, maar het lijkt alleen voor throttle te gelden, niet voor pitch. Dan kan failsafe dus niet de schuldige geweest zijn.SmartSafe is a safety feature on the throttle channel only
SmartSafe is automatically set when the system is bound. It’s important to have the throttle stick in the low position to store low throttle during binding.
Heb je je failsafe al eens daadwerkelijk getest, dus door je zender uit te doen terwijl de heli draait? Wel je hoofd en staartbladen er eerst afhalen natuurlijk ;-)
Wat gebeurt,
tijdens hover, lipo rond 1 min oud,
gaan alle 3 swash-servo's op vol negatief pitch,
throttle stick reageert niet meer, alles andere werkt !!
Over die ene servo: dat zou dan bijzonder zijn als het in de zender zat.
de zender stuurt op de knuppel altijd alledrie de servo's aan. als er 2 werken, en 1 niet meer luistert, zou je eerder aan een brakke servo denken..
of jij moet in je monitor menu kunnen zien dat hij dat kanaal vol uitstuurt..
Ik heb nl ook al een bijna nieuwe servo zien blokkeren.. was toevallig een nieuwe serie align servo..
