Note: There are two versions of the main PCB in the 9x. The later ones (aka Turnigy V2) have a pad
where the Purple wire will be connected. The vast majority of the 9x's out there are the late style.
The early ones do not have the pad; instead they have a pad on the wrong trace. If you have an early
style board, you can still do the mod, you just have to be very careful with your soldering, as you will
be soldering to the end of the surface mount resistor shown. The early style is shown in the picture
below with the purple (violet) wire soldered to the end of the resistor. Note the red circle. On the early
style, you cannot use that pad. The CORRECT connection is to the 7
th
resistor from the left on the
early style boards:
Nou is het al weer even geleden dat ik de mijne heb geflasht, maar volgens mij moet je toch echt gewoon MOSI op MOSI en MISO op MISO solderen hoor.Dus al pak ik het soldeerpunt van de Mosi en ik leg de andere kant op de miso van de USB...
