Nine Eagles Solo Pro
  • Topicstarter Topicstarter Leeuwarden
  • Startdatum Startdatum
Kan het niet laten maar bij qaurtel 5 eurie.Heb daar me pro solo gekocht en zag ze liggen.Vlieg niet met veel wind buiten anders is de copter weg hahahahhahahaha:D
Bah vandaag helicopter binnen gekregen, trimmen enz ging redelijk en terwijl ik ermee bezig ben vliegt hij tegen het plafond.
Vliegt er één van de linkjes af en kan hem niet meer vinden :(
Die uit de NE4260006 set ....
Net maar besteld bij Hobbyking want in NL EUR 4,25 betalen wat daar 80cent kost vind ik wat overdreven....
Maar kan dus voorlopig niet vliegen :(
EPA mode is er juist voor om dit probleem op te lossen.
Werkt als volgt
A: Sometimes a little trimming, and adjusting the link between servo and swash to compensate the difference might work. But otherwise, EPA or End Point Adjust is what you need. This is a hidden mode in the transmitter, that needs a special procedure to access it. As I recall Himalaya was the first to provide this information, and here is how you do it:​
**** EPA, or End Point Adj. ****​
▲ enter Sub Trim Mode
▲ unplug the lipo of your bird and plug it back in to enter EPA adj.
△ to set Aileron left end point, push&hold right stick to max. left positon, press T4 to adjust, right = less throw, left = more throw.
△ to set Aileron right end point, push&hold right stick to max. right position, press T3 to adjust, up = more throw, down = less throw.
△ to set Elevator forward end point, push&hold right stick to max. forward position, press T1 to adjust, right = less throw, left = more throw.
△ to set Elevator backward end point, push&hold right stick to max. backward position, press T2 to adjust, up = more throw, down = less throw.
▲ press the back button to save&exit when done.​
I would recommend to carefully watch the servos move when you do this EPA trim. Stop moving when the servo sliding block is 1mm apart to the hardware limit. Hitting the hardware limit will cause the servo lock up, you may have to manually spin the tiny servo gear to rescue it from the lock-up. The next picture explains what T1~T4 here all stand for. It's the four trims in futaba order, T1~T4 from right to left.​
For completeness, this is the link the the original posting which contained this information: http://www.rcgroups.com/forums/showp...postcount=2804
Wellicht had je dit op deze manier ook al gedaan.
Niet verkeerd om nog een voorbeeld te krijgen.
Anders toch misschien kijken naar een andere receiver, zijn vrij dure krengen​
je moet 3 of 6 keer op het knopje achterop drukken om in sub trim mode te komen
@slain, dat is inderdaad zo. Ik geloof dat je in het submode komt, zender uitzetten en weer aan en dan zit jein de EPA mode. Als ik het niet vererd heb. Erg goed dat je dit erbij vermeld.:D
Bijna goed, niet zender uit zetten, maar de accu even uit de heli en direct weer terug plaatsen, als je in subtrim mode bent. Let dus op dat je niet in subtrim mode zit en tegen een lege accu aan loopt, je er een verse in stopt en dan ineens in EPA mode zit...
Ik heb dezelfde TX bij de Skyrunner zitten maar ik vind hem net iets te lomp of te bol of zo.
Hij kan snel uit een hand glippen als je met je andere hand de heli of het vliegtuig vasthebt.
Maar ik zal wel weer de enige zijn die dat vind LMAO
Nee hoor, ik vind het ook ondingen. De grip ligt mij zeer slecht, totaal niet ergonomisch. Daarbij moet ik deze zenders (meestal) 2 keer aanzetten voordat deze ook aangaan. Goedkoop ogend, hard en glad plastic.
Wat de een fijn vindt, is niks voor de ander. Zelfde met computermuizen bijv, ook zoiet. Ik heb er geen last van, en vind de zender beter in de hand liggen dan die van mijn HobbyZone Champ bijv. En op de een of andere manier gaan ze bij mij altijd de 1e keer al aan.
Klopt is voor iedereen weer verschillend, ik vind hem niet echt lekker maar ook niet echt vervelend in de hand liggen en hij gaat altijd netjes bij de 1e keer aan.
...En op de een of andere manier gaan ze bij mij altijd de 1e keer al aan.
Niet meer als normaal. Of wou je met deze populaire bewoording indirect zeggen dat je me niet gelooft of dat zoiets bijna niet voorkomt?
Ik heb er 2, en als je deze snel aanzet, grote kans dat er niks gebeurd. Volgens Quartel komt dit erg vaak voor. Voor de rest geen probleem, want als hij valt niet uit ofzo. Dat valt dan weer mee.
Phew, was al bang dat ik iemand voor het hoofd zou stoten.
Tja, ik vindt ze echt te lomp, ze hadden hem wat kleiner en minder rond moeten maken. Het ding glipt echt zo uit je handen als je buiten vliegt, soms land de glider op het gras en dan worden je handen een beetje nat.
Maar goed, dat mag de pret niet drukken.
Klopt inderdaad. Ik moet de zenders ook meestal twee keer aanzetten.
Ik geloof je best, maar ik denk dat jij en Quartel dan slachtoffer geworden zijn van minder eerlijke handelaren. Het schijnt dat met enige regelmaat defecte en naar de fabrikant terug gestuurde spullen alsnog worden doorverkocht, vaak naar landen buiten China. Ik heb ook al verhalen gehoord van Solo Pro's waarvan de flybar al verbogen was, of een gewichtje miste, dat nergens in de doos terug was te vinden. Met andere woorden, er is mee gevlogen, gecrasht, terug gebracht, en vervolgens weer ingepakt en verscheept naar het buitenland, onder het motto "terugsturen is voor de arme sloeber die deze defecte heli treft toch duurder dan wat de heli waard is dus, die zien we nooit meer... terug!"
Ik heb het ook meegemaakt met die 3 kanaals heli'tjes bij achteraf gezien minder betrouwbare verkopers op eBay, bijna 100% uitval, wat zelfs voor dit goedkope spul aan de hoge kant is.
Dat Quartel zegt dat het normaal is baart me daarbij nog het meeste zorgen, dat je door sommige minder ethisch ingestelde chinese handelaars wordt opgelicht kun je een beetje verwachten, maar een modelbouwzaak heeft een naam hoog te houden, en door dit soort opmerkingen klinkt het alsof ze de verantwoordelijkheid van zich willen afschuiven. Of ik heb juist de slecht werkende zenders gekregen, omdat ik ze nooit 2 keer hoef aan te zetten, niet bij mijn Solo coax, mijn Solo Pro, mijn rebranded Solo coax alias Merlin Tracer 60, en mijn Bravo SX. ;)
Dude.....dit zei ik laatst tegen wat mensen. Het verklaart ook waarom er ineens spotgoedkope batches van interressant spul ineens op de meest vreemde plaatsen opduiken.
Achteraf blijkt er toch iets mis te zijn met het product terwijl de soms geavanceerde technologie ogenschijnlijk voor veel te weinig wordt aangeboden
Misschien zit ik ernaast.....
Dat zal zeker in een deel van de gevallen retour gestuurd spul zijn wat op die manier gedumpt wordt.
Die opmerking van Quartel over de NE zender doet me trouwens ook denken aan een akkefietje wat ik jaren geleden met een bij hun gekochte zeilwinch had. Die ging soms vanzelf draaien, met gevolg dat de schoten veel te strak werden getrokken. Paar keer terug naar de winkel, eerst lag het aan de ontvanger accu, die zou niet stabiel zijn. Andere accu, weer hetzelfde probleem. Motor van de winch zou niet goed ontstoord zijn, maar het was nu opgelost. Probleem was snel weer terug, moest ik maar nieuwe zender en ontvanger kopen. Ik dacht, "de groeten" en ben zelf gaan kijken, aangezien de garantie weinig bleek voor te stellen. Bleek dat als je een bepaalde plek op de behuizing aanraakte, de winch raar ging doen. Dus ik een stukje van de behuizing verwijderd, tape erover om te voorkomen dat er vuil in het binnenwerk zou komen, en nooit meer storing, ook niet met mijn "instabiele" ontvangeraccu...
Als ik dan hoor dat ze het normaal vinden dat je een zender 2 keer aan moet zetten voordat hij werkt, klinkt mij dat als "we weten dat er een probleem is, maar willen/kunnen er niets aan doen, dus zeggen we dat het zo hoort..."
