J
jurgen35
Guest
Kan het niet laten maar bij qaurtel 5 eurie.Heb daar me pro solo gekocht en zag ze liggen.Vlieg niet met veel wind buiten anders is de copter weg hahahahhahahaha
Kan het niet laten maar bij qaurtel 5 eurie.Heb daar me pro solo gekocht en zag ze liggen.Vlieg niet met veel wind buiten anders is de copter weg hahahahhahahaha![]()
EPA mode is er juist voor om dit probleem op te lossen.
Werkt als volgt
A: Sometimes a little trimming, and adjusting the link between servo and swash to compensate the difference might work. But otherwise, EPA or End Point Adjust is what you need. This is a hidden mode in the transmitter, that needs a special procedure to access it. As I recall Himalaya was the first to provide this information, and here is how you do it:
**** EPA, or End Point Adj. ****
▲ enter Sub Trim Mode
▲ unplug the lipo of your bird and plug it back in to enter EPA adj.
△ to set Aileron left end point, push&hold right stick to max. left positon, press T4 to adjust, right = less throw, left = more throw.
△ to set Aileron right end point, push&hold right stick to max. right position, press T3 to adjust, up = more throw, down = less throw.
△ to set Elevator forward end point, push&hold right stick to max. forward position, press T1 to adjust, right = less throw, left = more throw.
△ to set Elevator backward end point, push&hold right stick to max. backward position, press T2 to adjust, up = more throw, down = less throw.
▲ press the back button to save&exit when done.
I would recommend to carefully watch the servos move when you do this EPA trim. Stop moving when the servo sliding block is 1mm apart to the hardware limit. Hitting the hardware limit will cause the servo lock up, you may have to manually spin the tiny servo gear to rescue it from the lock-up. The next picture explains what T1~T4 here all stand for. It's the four trims in futaba order, T1~T4 from right to left.
For completeness, this is the link the the original posting which contained this information: http://www.rcgroups.com/forums/showp...postcount=2804
Wellicht had je dit op deze manier ook al gedaan.
Niet verkeerd om nog een voorbeeld te krijgen.
Anders toch misschien kijken naar een andere receiver, zijn vrij dure krengen
@slain, dat is inderdaad zo. Ik geloof dat je in het submode komt, zender uitzetten en weer aan en dan zit jein de EPA mode. Als ik het niet vererd heb. Erg goed dat je dit erbij vermeld.![]()
...Maar ik zal wel weer de enige zijn die dat vind LMAO
Nee hoor, ik vind het ook ondingen. De grip ligt mij zeer slecht, totaal niet ergonomisch. Daarbij moet ik deze zenders (meestal) 2 keer aanzetten voordat deze ook aangaan. Goedkoop ogend, hard en glad plastic.
...En op de een of andere manier gaan ze bij mij altijd de 1e keer al aan.
Niet meer als normaal. Of wou je met deze populaire bewoording indirect zeggen dat je me niet gelooft of dat zoiets bijna niet voorkomt?
Ik heb er 2, en als je deze snel aanzet, grote kans dat er niks gebeurd. Volgens Quartel komt dit erg vaak voor. Voor de rest geen probleem, want als hij valt niet uit ofzo. Dat valt dan weer mee.
Het schijnt dat met enige regelmaat defecte en naar de fabrikant terug gestuurde spullen alsnog worden doorverkocht, vaak naar landen buiten China.
Dude.....dit zei ik laatst tegen wat mensen. Het verklaart ook waarom er ineens spotgoedkope batches van interressant spul ineens op de meest vreemde plaatsen opduiken.
Achteraf blijkt er toch iets mis te zijn met het product terwijl de soms geavanceerde technologie ogenschijnlijk voor veel te weinig wordt aangeboden
Misschien zit ik ernaast.....
