Zojuist iets gevonden over de regelaar :
Pentium 60 amp controller
Gregory Granville
I have several of the H-Wing controllers and am impressed with their efficiency. They actually run cooler than most of the other higher priced, high current ESC's I've bought. A nice range of programming options, and the programming card is really slick.
Things I would like to see - adjustable PWM settings, and a governor mode that works. Gov mode has not worked with any of the motors I've tried. It can also cause the ESC to act very unpredictably. Heli pilots - just leave the governor mode off and fly throttle curves. Works great that way...Be careful with timing settings on some motors. If it starts jumping or kicking, back off on the timing settings immediately.
H-Wing Pentium 60amp Speed Con
Tomasz Patan
As always great for the price. I use mine with 5sA123 18V battery pack on a helicopter with 700W setup. 3A switching BEC is handling easily 4 high current draw servos. It is very easy to setup, simple and works great. Cables are very long and flexible. Comes in red hetshrink not black like on a picture
Low price, High performance!
Herman Kruisman
This is one of the best esc's i have used so far. It is not the smallest 60A eas BUT the switchmode bec works perfectly without any glitches so that is a very big plus. It run's very smooth but when you play with the throttle to fast the motor may stall! Be aware of this! Normally this is never a problem, i just had to find 1 thing wrong ) You can never find a esc with the same functions for a lower price. It works great even when it gets hot (55A, NO cooling). Motor efficiency is just as good as other brands like Jeti / Hacker or Castle creations. They to got quite hot at 55A in the same plane. OEM RC works the same but costs 1/2
(or even less)
