Gegevens even in de prop calculator stoppen (per motor).
14X5 prop
22.2V
6400 rpm
1487 gram thrust.
12A
266 W
Estimate Propeller Static Thrust
Moet dus makkelijk kunnen.
Kleinere regelaars zijn meestal voor 2 tot 4 S lipos.
Deze DJI E600 20A kan echter 6S aan.
DJI E600 Tuned Propulsion System (with 4 Motors, ESCs, 4 pair Props) - DronesVision
SPECIFICATIONS OF DJI E600
Recommended load: 600 g/axis
Recommended battery: 6S Lipo
Maximum Thrust: 1600 g/axis
Working Temperature: -5°C ~ 40°C
Unit per Package: Quad or hexa
ESC Current: 20A OPTO
ESC Signal Frequency: 30Hz~450Hz
ESC Voltage: 14.8 V~25.2V
Battery: 4S~6SLiPo
Motor Stator Size: 38×8mm
Moto KV: 415rpm/V
Motor Weight: 90g
Propeller Diameter / Thread Pitch: 33x11cm / 12x4.2inch
